Seca 750 anyone?
  • daveyg
    • Feb 2009
    • 411
    • Boise, ID
    Seca 750 anyone?
    A friend is giving me a running Seca 750 that has no title, but I'm trying to decide what to do with it. Kinda leaning toward parting it out, but part of me wants to play with it and build something funky outta it. Question is, does the driveshaft spin bassackward like the 11, or does it spin the same direction as any typical small car driveshaft? Thoughts from the group? Would it be impossible to chain drive conversion it? (If a guy knew a competent machinist) thanks y'all!
    BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
    80 XS1100SG(cafe in progress *slowly)
  • daveyg
    • Feb 2009
    • 411
    • Boise, ID
    I guess if I'm gonna do something crazy I could just mount the engine sideways with a hub to a sprocket mounted direct to the output shaft...
      Unless your plannin' on riding that scoot in reverse, all shafty scoots driveshafts turn same direction, no matter what side there located on.
      Converting to a chain-drive.............anything is possible if your pockets are deep enough............a waste of good money IMO though.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Did they make a chain Seca 750 ?
        Back in 80 something I raced a 750 Seca with my SF, let him take off in the lead thinking on this long straight I'd pass him. Never did gain any ground on him, thought it was because of the chain ?
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • Prisoner6
          • Aug 2013
          • 1184
          • Phoenix, AZ
          Hey, Unca D -
          No ...
          Yamaha never offered a factory-produced Seca 750 in a chain-drive version.
          The Seca 650 was also a shaftie, but the Seca 550 did have chain drive.
          Marco
          1979 Honda CBX
          2002 Kawasaki ZRX1200R
          WE MISS YOU, DON
            Nope, quarter mile time differences between it and the XS11 comes down to less than a 'missed shift'.........unless it's a Seca turbo 750, of which there was only a few thousand produced. Definitely a stylish sport tourer 'of the day'.
            • Prisoner6
              • Aug 2013
              • 1184
              • Phoenix, AZ
              Yamaha never produced a Seca Turbo 750 ... but they did offer the Seca Turbo 650 (653cc) for the 1982-83 model years ...
              Marco
              1979 Honda CBX
              WE MISS YOU, DON
                • 3932
                Mmhmm. I have two. Horrible bikes.
                • daveyg
                  • Feb 2009
                  • 411
                  • Boise, ID
                  Hmmm... Interesting food for thought. Thank ye gentlemen! I'll post pics once it's in my possession.
                  • MindWebs
                    • May 2009
                    • 431
                    • Baldwin, WI
                    No, they can not be converted to "chain drive".
                    the XS11 has a "middle drive gearbox" that can be un-bolted from the transmission, and replaced by a custom built gearbox with a chain driving sprocket.
                    The XJ750 Seca, has an intrigrated "middle drive", it's built into the tranny castings and cannot be un-bolted.
                    and good luck whooping on a 750 seca with an XS11.
                    unless you have a very long strait road.
                    the XS will pass at 125-135MPH
                    (XS11 approx max speed 140MPH) depending on condition of bike
                    (Seca approx max speed 120-130) depending on condition of bike
                    the Seca was originally designed as a track racer
                    (crotch rocket, before those existed)
                    the motor is solid mounted in the frame so there is zero hp lost in mounting twist.
                    and the timing is hotter then the maxims, and carbs are jetted slightly differently.
                    sweet little nasties, i like them .
                    i own both and prefer the seca as my daily driver.
                    but, as you notice i am very bias toward the seca....
                    it'd the difference between a battle axe and a war hatchet. (xs11 to 750 seca).
                    • daveyg
                      • Feb 2009
                      • 411
                      • Boise, ID
                      Yeah I've come to the realization that the 'middle drive' is housed in the case. But I'm not thinking of a motorcycle, I'm thinking mounting engine longitudinally in say, a go kart/sandrail with a sprocket mounted off the shaft flange, running to a solid straight axle rear shaft. I've got a spare axle off a Honda 'big red' ATC 200 that would make a great donor. Thinking 2 seats side by side, atv tires front n rear. Just thinking right now though, I don't even have the bike in my possession yet.
                      • MindWebs
                        • May 2009
                        • 431
                        • Baldwin, WI
                        how about a C.V. shaft axel off a big 4 wheeler?
                        then all you would need to do is adapt the drive shaft.
                        but there is lots of ways to set that up.
                        shroud the motor and put an electric fan on for cooling
                        that would be one mean nasty shifter cart, i alway's wanted to build something like that. put an electric solinoid for shifting, or air shifter.
                        switches on the stearing wheel, clutch and throttle on the floor...
                        i can here smell the rubber burning from here....
                        use a nice soft bucket seat out of a car, to help soften the ride...
                        Sweet!!
                        sounds like a blast!
                        • daveyg
                          • Feb 2009
                          • 411
                          • Boise, ID
                          My thoughts exactly! Would be one hell of a mean 2 seater shifter kart! I'd build a swingarm on the rear for suspension, front I'd need to do some thinking... There's an ATV wrecker not far away that I could probably get a whole front end from.
                          • Brent
                            • 959
                            Adventure
                            I like what you have done with your Seca. It Sure looks the adventure bike part.
                            Brent in GA
                            • MindWebs
                              • May 2009
                              • 431
                              • Baldwin, WI
                              Twisted whiskers..
                              Thanks Brent.
                              You have some intresting machines too.. i'd imagine you have a hard time picking the machine to take that day.
                              i just have a hard time deciding what my machine is or what it should do.
                              2 sets of upgrades ago.
                              Newest start to madness this winter
                              Yes those are xs1100 rims front and back on a xj750 seca.
                              (not bolt in upgrades, machining required.
