83 Venture
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    83 Venture
    There is an 83 Venture, 45K, what to look for ? Not Venturer.
    Thanks! Done
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • 6765
    Thanks! Done
    Venture Royales'...had the same 2nd gear problems so i have heard...other than that IDK... They are V4 motors
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Venture
      OK, so the Venture, not the Royal is subject to the same trans. problem we have on the 11.
      Same fix ?
      What other things should I look for ?
      Thanks, Done
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • tcoop
        • Nov 2009
        • 793
        • South Weber, UT
        The Venture and the Royals had the same 2nd gear problems. The problem was fixed in the 85 to 86 year bikes. Mine I just live with it only slips out when I open the throttle hard. One thing that you may watch for is a problem with the TCI. The diodes are known to go bad. If you're good at electronics it can be fixed. A good used one can be bought for a price $200 to $300 on E-bay. An after market one (Inditec(I think that's what its called) is what I have) can be had for about $250. Clean both Master cylinders and all tree calipers and you will have a great bike.
        Ty
        78 XS1100E - Now in Minnesota
        80 XS1100LG - The Punisher
        82 XJ1100 - Daughter's Bike
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Thanks Guys ! Seems to have the patina of an 83 but for 31 it's not bad. $1300 seem fair ?
          76 XS650 C ROADSTER
          80 XS 1100 SG
            • 6765
            sounds fair...
            • D0wn5h1ft
              • Aug 2013
              • 515
              • Westerly, RI.
              Predecessor to the VMax. Powerful bike.
                Not bad at 100ponies. They're not quite as quick as my 1100Venturer, but a bit heavier with the additional farkles on them and water cooled. Same platform motor as the later V-Max, but not even in the same class as the 180ponies of the first gen. V-Max.
                  • 3307
                  Venture has motor platform as the Gen I Vmax, but as Motoman said, tuned to around 100hp.
                  Gen II Vmax has the monster 180 hp/110 ft/lbs. My wife's uncle has a Gen II Vmax (2010) and it is the most ferocious accelerating vehicle I have ever sat on or in. Absolute insanity, but huge fun!
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                  • Prisoner6
                    • Aug 2013
                    • 1184
                    • Phoenix, AZ
                    A buddy of mine had a Gen II V-Max ... I say had because he sold it 6 months after buying it! He said it was too powerful for him ...
                    But, he did let me ride it, and ferocious is a good way to describe the kind of acceleration this bike has!
                    But it goes beyond that ... I would say it is mind-numbing acceleration! And the chassis appears to be up to the task of handling that much power ...
                    Incredible machine!!
                    Marco
                    1979 Honda CBX
                    2002 Kawasaki ZRX1200R
                    WE MISS YOU, DON
