Need 1982 Honda Sabre Carb Slide with Diaphragm!
  • Bill__Woods
    • 281
    • Circleville, Ohio
    My friend needs an 1982 Honda Sabre VF750s - Carb Slide with Good Diaphragm.
    I belive the same carbs are used on the 750 Magna and Interceptor also.
    email my friend if you can help
    Clay - jcn_72@yahoo.com
    Thanks!
    Bill Woods
    1981 Yamaha XS1100SH (Eleven Special)
    1985 Kawasuki GS425 Mojave ATV
    2006 Yamaha Wolverine 450 4x4 ATV
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    Re: Need 1982 Honda Sabre Carb Slide with Diaphragm!
    Thanks!
    If there is a leak in the diaphram it's easy (and cheap) to fix with Yamabond 5.
    Geezer
    • desert1
      • 750
      • Grand Desert, Nova Scotia, Can.
      My diaphragms
      Noticed on my carb slide/diaphragm assembly on the 79 I'm rebuilding that 3 of the slides will not lift up more than a 1/8 inch or so there not dirty or seized in anyway and move a bitup n down the only assembly that lifts all the way up is the #1 carb....a previous owner may have changed clip positions and reassembled the wrong way, unsure until I ttake them apart.......keep my eyes open for Sabre carbs by the way.
      Bruce
      Bruce Doucette
      Phone #1 902 827 3217
      • Bill__Woods
        • 281
        • Circleville, Ohio
        Thanks for the tip Geezer, I will keep it in mind. We have decided not to repair this one. there is a tear very close to the slide, and a wear marks all the way around it. I is roten in the spot it flexes the most.
        Let me know what you find with your slides not moving up & down Bruce.
        Bill Woods
        • Geezer
          • May 2003
          • 2985
          I won't argue with your diagnosis of the slide, but I've repaired many diaphragms that had small rotten spots. The Yamabond 5 fills in the damaged spot and the repair is almost as good as new. Yamabond 5 is as flexible as the material the diaphragm is made out of. The only thing I didn't mention is to completely degrease the diaphragm before applying the Yamabond. This is only common sense but it doesn’t hurt to mention.
          I only had one good slide for my 80 Mongrel and about 7 bad ones. I repaired them all and I figured I'd pick the best looking 3 out of the batch of repaired ones. I ended up using all repaired slides and one looked as good as the others.
          Geezer
          • sksxs1100
            • 331
            • Bridge city,TX (Beaumont area)
            I sent robert at motorcyclecarbs.com 2 complete racks from two 82 v45 sabre 750 check with him to see about them... i never took them apart so i dont know there condition
            Shawn
            78 XS1100E "Black Rat"
            78 XS1100E Parts
            www.hotrod1972.com
