Model SF
  • Ben Geutskens
    • Jan 2014
    • 35
    • Norg, Netherlands
    Model SF
    I recently acquired a 1979 Yamaha XS 1100 Eleven Special, Engine- and Frame # 3H4001161 also known as Model SF (Canadian).
    My problem is how to make sure I buy the correct spare parts (apart from buying these from the Yamaha dealers, which often times are 5 times as expensive). Sellers’ websites only mention “fits SF” in a very few cases. Which parts listed for “XS 1100” or “XS 1100 S” will fit my bike?
    My problem is that I don’t know on which aspects various models differ from each other.
    79 SF Canadian
  • Gallaecus
    • May 2011
    • 251
    • East Haven Connecticut
    e f g h refers to the years, 78 79 80 81 respectively
    s is for special no s mean standard
    canada may be different ??? idk...
    goto xs11.com FORUMS..... under REPAIR section....there is an interchange guide
    then goto xs11.com forums......Miscellaneous....Miscellaneous tip...is your serial number identification guide.
    what parts are you trying to find?
    Steven
    1981 XS 1100 LH
    1979 XS 1100 SF
    • Ben Geutskens
      • Jan 2014
      • 35
      • Norg, Netherlands
      Model SF
      Thanks a lot. I'll study the lists more carefully, but they look promising.
      What I need is caliper revision sets front and rear, main brake cylinder revision set rear, brake pads front and rear, tank cover seal ('filler'), air fillter, O-rings for lube oil filter.
      Looks like PartsNmore has all this stuff, if parts listed as "S" will do.
      79 SF Canadian
        Hey Ben,
        I understand your question, in that yours is a Canadian model. Now I know that 90% of the special parts interchange any year. The seat and side covers being the most noticeable exceptions, but there are some items specific to the SF. As for it being a Canadian model, I would suspect only the speedometer is different as your primary measurement of speed is KPH instead of MPH. But I do not know for certain that is the only difference.
