I picked up a barn find recently, a KZ650 that must have sat for a long time. It was ugly and missing a few parts. I have cleaned and rebuilt the carbs both with carb cleaner and using ultrasonic cleaning. I installed new ignition coils (they were missing), new plug wires, caps and plugs. I have verified that the right side coil wires go to #1 & #4 and the left side goes to #2 & #3. Installed a new battery, changed the oil and filter, installed new throttle cables, new fuel lines. Also reset the gap on the points.
With gas in the carbs and using the starter button or the kick start the engine will not fire up. I have a 78 KZ 750 that I have to pull in the clutch in order to start so I have tried that as well on the 650.
What am I missing? Help is appreciated.
And throwing money at it doesn't always fix things, although, if you have a lot of spare money, there are people who would be glad to charge you lots to do what you can do yourself.
