Howl'n Windjammer III
  • je2wheeler
    • Feb 2010
    • 180
    • Moved to NC to help my Dad
    About two months ago, my ‘Jammer developed an occasional howl that was not related to engine speed, more like road or wind speed. At first I blamed it on road surface as the howl at first came and went. As the miles piled on the howl became more constant and louder and I continued to elevate probable causes until I noticed the high mileage Metzler Lazertec sport front tire has fletching shaped center tread blocks that are starting to protrude a little higher than the rest of the tread. I am sure this has set up the harmonic vibration bring the howl to my fairing. I tried adjusting the tp up and down some with little improvement. I do pre-ride pressure checks with my little "Slime" gage so improper tp is not the issue. I began running sport tires on the front years ago to help with the higher traction requirements of the front and a touring tire on the rear. Front and rear have generally worn close to the same rate. Looks as if I will be replacing the front with a different model and/or brand of sport tire before it’s time.
    1979 XS 1100 Special - Nicknamed "MONSTER"
    ATC fuse box
    Braded stainless brake lines
    4/2 aftermarket exhaust(temp until stock is re-chromed )
    V-Max auto cam chain adjuster
    Brake light modulator with reserve brake light bypass
    Vetter Windjammer III faring
    Tkat Fork Brace
    "Americans have the right and advantage of being armed; unlike the citizens of the countries whose governments are afraid to trust the people with arms”
    James Madison, The Federalists Papers
    Do you have vents in the windshield? Are they open? I find that I get a howl at certain speeds if the vents are closed. It's an air pressure thing.
    • je2wheeler
      • Feb 2010
      • 180
      Nope, no vents. Thanks for the input.
      ATC fuse box
      Tkat Fork Brace
        • 3191
        Something to think about is that you hear much more from the engine with a Jammer. Make sure that all is well that way. First time I rode with a jammer I thought me motor was about to come apart. Many noises will tranfer from one place to another. It is entirely possible that you could be hearing anything from a bad front axle bearing to a low lubrication on your middle drive. JAT
        • je2wheeler
          • Feb 2010
          • 180
          Originally posted by Rasputin
          Something to think about is that you hear much more from the engine with a Jammer. Make sure that all is well that way. First time I rode with a jammer I thought me motor was about to come apart. Many noises will transfer from one place to another. It is entirely possible that you could be hearing anything from a bad front axle bearing to a low lubrication on your middle drive. JAT
          All very true, wind noise goes down and engine noise goes up. However, I replaced the front wheel bearings during the restore and the middle and final drive are checked monthly This noise was not there for the first several months after I added the 'Jammer, the noise coinsided with tire ware and the howling is still there with clutch in and engine cut at a 60mph coast. Thanks for the help
          ATC fuse box
          Tkat Fork Brace
          • je2wheeler
            • Feb 2010
            • 180
            Proof will be in the puddin'
            Me again, this howlin' thing will be put to rest when I change the front tire but I can not bring myself to pay for a tire before it's time - so stay tuned
            ATC fuse box
            Tkat Fork Brace
              Hi je2,
              what you need is a bro with an XS11 (or an XS650/750/850, it's the same front wheel) that will swap front wheels with you for a day or so. If the noise moves to buddy's bike, you'll know for sure.
