vacum advance
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    vacum advance
    I am having trouble with my vacuum advance on my xs1100s. it is jumping up and down at an idole and not rapping when i rev it up it stops. or if I pinch the vacuum line off the thing makes a rappimg sound like a bad lifter.
    how do i fix it it sounds bad i saw it jumping when i took the cover off while it was running.put pressure pn the plate that the diaphram module that runes it and it stops rapping is there a rubber stop in there that stops the noise. where can i get a new one or how do i fix the old one looks like there is a rubber plug on the top of it
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    where is the vac hose hooked to ??? i have vac advance units if you need one
    • brownbear1000
      • May 2007
      • 83
      vacum hose
      it it hook to the rubber manafoldon by the #2 carb
        There is a nipple on the #2 carb itself that it should be hooked to, NOT the intake manifold boot.
        By the way I am just west of you in Pewaukee.
        • brownbear1000
          • May 2007
          • 83
          vacum line
          will look thanks
          • brownbear1000
            • May 2007
            • 83
            fixed it ishoud have looked closer at it when i put the carbes back on this spring
