Late last year I picked up a 72 CL350 twin, and I have been working on it ever since. During the summer I noticed it was burning oil like mad and at one point after letting it sit for a few weeks the pistons seized for a short time. I was able to get it to go, but ever since it would backfire and had greatly reduced power. So the plan was to rebuild the top end.
I just picked up a new motor, which looks to be in great shape. The cam chain tensioner is spotless and the cylinders looks good, and the pistons look great. I know this because the motor is in pieces. Previous owner picked it up, also in pieces, but did not need it. So I plan on rebuilding this motor and replacing the current one, then rebuilding the original motor with a bore kit. I have never done this before so if anyone has any tips it would be great. I assume I will be starting this with the left side piston at TDC when I put this all together, and then the cam in the TDC position as well. Is there anything else I need to worry about when I rebuild this?
