XS750 headshots
    XS750 headshots
    My son took his XS750's top end apart to investigate an oil leak.
    Here are shots down the exhaust ports:-
    #1 valve is bone white
    #2 valve is sooty black
    #3 valve is oily black
    And yes! Those are all from the same engine. Ideas anyone?
    Is it possible number one is also processing oil only it is getting burned up to be dry looking due to XSive heat from running so lean?? (yeah a bit of a reach really.)
    Otherwise, dunno.
    • Guy_b_g
      • May 2007
      • 790
      • Beverly Hills, Florida
      Goldilocks diagnostic method,
      1 is too lean.
      3 is too rich.
      2 is Juuuust right.
      Time to pull the carbs, maybe check on the ignition for #3 too.
      Guy
      '78E
        Update
        Hi list,
        our boy phoned today. Seems that if he will do a day's worth of splitting firewood for a former schoolmate's mother the lady will give him her Ex's '78 XS750 in exchange.
        Trouble is, this bike will be stored in our garage and as a loving mother my wife ain't mad at him, she's mad at me.
        There Ain't No Justice.
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          Yea, but that 78 was the one to have. A bit more Hp and torque I believe.
          Richard
          • Rickrod3
            • Jun 2009
            • 721
            • Oakland, New Jersey
            Hi list,
            Yea but, some things are worth the punishment.
            650SF
            XS1100SG Project bike
              Further update
              Well, the extra XS750 deal fell through, seems that not all of the parties involved were OK with it.
              But Eric's own XS750 is back together with re-lapped valve seats, new valve stem seals and it seems to be running OK.
              No road test yet, the stock exhaust has rotted to the extent that we had to cut one muffler off (the other had already broken off) and we are transferring the long reverse cones off his XS650.
              Then he gotta make a 3-way aquarium tube manometer to balance the carbs. Better yet he can make a 3 & 4 way manometer and balance my XS11 with it, he needs the experience.
              • rpgoerlich
                • Dec 2007
                • 643
                • Katy, Tx
                You really only need a 2 port manometer(easier to make) as #2 is the fixed one. You'll be syncing #3 to #2 and #1 to #2.
                It should have MIC II's on it which are easier to sync. MIC I's you have to go in from the bottom to get to the sync screw(a real PIA ).
                Richard
                  Originally posted by rpgoerlich
                  You really only need a 2 port manometer(easier to make) as #2 is the fixed one. You'll be syncing #3 to #2 and #1 to #2. - - - -
                  Hi Richard,
                  the manometer is just aquarium tubing and plastic tees, a few more won't hurt. And besides, he needs to be able to switch it to a 4-way to balance my XS11, don't he?
                    Latest update
                    The triple is running like a train now that we found #3 coil was 95% dead and put an XS650 coil out of the junk box in it's place.
                    The exhaust looks and sounds great with the ex-XS650 mufflers on and no oil leaks neither.
                    But my son says the road test shows the outfit will go 120+kph in 4th but is hard to get above 100kph in high gear.
                    So what is involved in putting an XS11 rear drive into an XS750 to put the gearing to where it needs to be for sidecar work?
                    Just see the posts on putting an XS750 rear drive into an XS11 and do it backwards or is there some unforseen little trick to it?
                      Fred, the XS750 coupler uses a wet coupler, no grease. The gear oil from the pumpkin lubes the inside of coupler and drive shaft splines and there's a seal on the '750 drive shaft that fits inside the '750 coupler.
                      You might be able to just remove the seal from the '750 drive shaft and grease it like an XS11. Let us now how it works out and take lots of pictures.
                      Regards,
                      Scott
                      • petejw
                        • 2269
                        • sydney australia
                        Hi Fred,
                        is he running stock main jets,
                        he might be running rich on the mains
                        that could prevent it revving out in top gear.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • rpgoerlich
                          • Dec 2007
                          • 643
                          • Katy, Tx
                          If you haven't already I'd check the plug caps.
                          What year is this one? 76/77? Still had points unless it was converted. 78/79 had electronic ignition.
                          Richard
