Went ahead and knocked a baffle from my stock exhaust
  • Bartolucci
    • Nov 2009
    • 58
    • Rochester, New York
    After spending several hours (literally) reading pros and cons as to knocking out baffles from a stock exhaust, I bit the bullet and decided to just knock out the first baffle. This is on an XS400 twin. So far, so good. I like the sound and it's by no means too loud. The plugs showed that I was running rich so I hope that this helps lean it out some. Going for a test drive now.
    TAB
    Tony A. Bartolucci
    Present Ride: 1982 XS400LJ Custom
    Former Rides: 1981 XS1100LH
    1975 Kawasaki 100 2 Stroke Enduro
    1975 Honda 750F
    Current Cool Cage: 1966 Chevy Impala 396
  • Bartolucci
    • Nov 2009
    • 58
    Update
    Took a 4 mile ride (it was freezing - 35 degrees out there!). Was very pleased. The sound is good, if anything still a tad on the quiet side. Best of all the bike pulled well at all rpms. Apparently, whatever change in back pressure was not detrimental.
    Next I will check the plugs.
    I need some suggestions on two fronts: 1) How long should I ride the bike before I check the plugs? 2) This bike has been a notorious hard starter (even before I made any mods). The battery is toast. Kick starting is an adventure. More distressing is that the bike can be all warmed up and if I turn it off, restarting can be a challenge.
    TAB
    Tony A. Bartolucci
    1975 Honda 750F
      It's a Zen thing.
      Originally posted by Bartolucci
      - - - I need some suggestions on two fronts: 1) How long should I ride the bike before I check the plugs? 2) This bike has been a notorious hard starter (even before I made any mods). The battery is toast. Kick starting is an adventure. More distressing is that the bike can be all warmed up and if I turn it off, restarting can be a challenge. TAB
      Hi Bart,
      1) 4 miles aught to do it. ( Actually that's a smartass remark. Do a search on "plug chop test" to see the methodology of checking carb leanness via plug inspection.)
      2) Oriental Wisdom sez that a question will contain it's own answer.
      Betcha the bike is a bitch to start because the battery is toast.
      Although you should run jumpers from your car battery and see how the bike starts then before spending the big bucks on a new battery.
