I picked up a barely running seca. I pulled and cleaned the carbs. The bike runs alot better, but I am having trouble with the engine returning to idle. The slides appear to move freely and I am convinced this is where my problem is. Does anyone know of a test I can perform to find out for sure? Would a leak in the diaphram or diaphrams cause this? Any suggestions would be greatly appreciated. Gary
81 750 seca
I picked up a barely running seca. I pulled and cleaned the carbs. The bike runs alot better, but I am having trouble with the engine returning to idle. The slides appear to move freely and I am convinced this is where my problem is. Does anyone know of a test I can perform to find out for sure? Would a leak in the diaphram or diaphrams cause this? Any suggestions would be greatly appreciated. GaryCy
I was always taught to respect my elders, but it keeps getting harder to find one. -
yep..
perhaps the slides, but not highly likely.
if there are no pinholes or tears in the diaphrams you are good there.
i have fought this problem on all 3 of my yamer's and it has alway's been a case of the carb needing syncronization.
if 1 is pulling differently then all will have a hard time returning to idle.
and you "need" to close down the YICS passageway.
it will allow you to give it a MUCH more accurite sync.
it can be done without tool, but i don't recomend riding it that way.
it's a good way to starve a cylinder.1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
Most bike problems are caused by a loose nut connecting the handlebars and the seat!!Comment
oh, yeah...
Here is the instructions for the yics tool.
i just loaded the file.
let me know if you need some bits of silicone hose, i may have some laying around yet.
if you have any questions, keep them coming, we like a chalenge.
Webs1979 XS1100SF Special.78 E motor/carbs, Jardine 4-2 exhaust, XS Green coils, Corbin seat, S.S. Brake lines, Hard cases, Heated grips.
Carb Sync
I bought a YCIS tool for syncing the carbs, and the tool helps out like you said. Thank you for your response. I inspected the diaphrams on the slides and I cannot see any holes or other damage and the slides appear to move freely in bores. Tomorrow I'm going to try adjusting the mixture screws. I'll post an update. Thank You, GaryComment
Read this post...
Now available for most bikes.
Thanks YahmanCurrent Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650Comment
YICS Eliminator
Thanks Dan.
It fits all of the XJ models with the YICS system. Just search "YICS Eliminator" on eBay.
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
See it here... http://www.youtube.com/watch?v=cBYT4C9_6AcComment
