Hi
I have an xs400, 1980 17k miles, (the one on this forum that previously had the blue smoke problem - thankfully fixed). Unfortunately, the starter went out, and I removed it in oreder to see if I could get it working again. It turned out to be a grounding issue. The big problem came when i replaced the starter and forgot to fish out the gear that turns the flywheel via a chain (REALLY stupid mistake, I don't need reminding!). On my way home, the gear became lodged in the flywheel locking up the entire engine, including the rear wheel (travelling about 35mph).
I pulled the cover off of the alternator and flywheel and managed to fish out and re-attach the gear and chain. Amazingly, after an oil change, the bike fired right up. It runs andshifts through all of the gears without any obvious issue, but I now have a rattle/knocking sound from what sounds like the right piston.
I have pulled the head cover and head. The cam chain/camshaft look ok, and there are no marks on the cylinders to indicate that a piston ring went bad. I pulled the valves to inspect them but don't really have any way to tell if they are bent. Is there a trick for this, or do I need a special machine?
Transmission and crankshaft seem ok, since the engine turns with almost no resistance now that there is nothing to compress. I didn't think to do a compression test before I pulled the head off, but when I turned the engine (with the valves closed, no rocker arms attached) I could hear the air leaking out. Should I hear that regardless of valve condition? Also, when I pulled the head off, I noticed that three of the valves were covered with black sediment, and one (exhaust on the cylinder that is suspect) was covered with white sediment. All in all, the compression chambers are VERY dirty, but I don't think that has anything to do woth the problem since it would have been that way before my little starter mishap.
Sorry for the essay, and thank you if you actually read this far! Any help at all would be appreciated!
Rich
Rich
