I have an XJ650 that whenever I start it and try to put it into first when it's cold, it dies. It's sounds a little rough going into gear. After a few tries it will finally take and keep running and then has no problems afterwards; only on first start up. Any clue?
XJ650...getting it into first.
'81 XS1100LH (almost ready)
Previous ride:
'86 VF500F
'82 XJ650J Maxim
"That which doesn't kill you most likely will the second time." -Eugene Krabs-Tags: None -
Hi BlackD,
I have an XJ650 too. Transmission on mine is much quieter than XS.
WHat grade of oil iin the engine. When did you last change it?
I find mine gets clunky when it's time for an oil change.
Try starting it on the centre stand. If it takes more than a gentle touch to stop the wheel turning the clutch is dragging which may just be an adjustment (as already posted)
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
I had one that sat for a while and 2 of the frictions were bonded to the steels...I had to disassemble and clean the steels and re-soaked the frictions after cleaning them as well. Like Phil said start it on the stand, see if the wheel starts spinning. It might just need an adjustment.RichardComment
Sounds like the first thing I'm going to try is to adjust the clutch cable. If this doesn't work then I guess it's back to the drawing board.
I just changed the oil in it BTW. I used 10w-40 Yamalube. I just went to the dealer, told them what bike I had, and bought what they put on the counter. I hope it was the right choice
Previous ride:
'86 VF500F
'82 XJ650J Maxim
"That which doesn't kill you most likely will the second time." -Eugene Krabs-Comment
Hi BlackD,Sounds like the first thing I'm going to try is to adjust the clutch cable. If this doesn't work then I guess it's back to the drawing board.
I use 10w40 too. Just thought a heavy oil might be causing your problem.
Previous ride:
'86 VF500F
'82 XJ650J Maxim
Hi BlackD,
That clutch might jut need a good long ride to fix it. Good high speed run along your favorite road or to some exotic destination you have never visited before. I have been told the more they see wrenches the more they want to be wrenched. the carbs like a good stretch of full throttle too
