Looking for a little help with this,
My friend purchased a cx 500c, the guy he bought it from jump started it and ran fine. So he put in a new battery, filled the tank, added some seafoam, reconnected the manifolds (they were off for some reason) put in a new air filter and we started working on it.
We ran into some problems though, the bike started to backfire and didn't sound quite right. We sprayed some water on the headers and the right header was not hot at all, maybe warm to the touch and the other got hot very fast.
We checked for spark and both had it, we swapped plugs to no effect. And replaced the resistors in the caps (they are known to be problematic).
Here is where it is now. With the bike running, pulling the cap on the right cylinder has no effect on the engine. Pulling the left cap kills the engine. When starting, if the choke is all the way out and the left cap is pulled the bike will start and run on the right cylinder only for a short time, it will begin to rev (never putting choke back in) and then die.
We took off the carbs for now and they look clean, but we will take them apart to look some more.
If the right cylinder is only firing when the choke is out does that mean its not getting enough gas through that specific carb?
Any ideas?
Any ideas?
