Suzuki 800 Intruder
    • 3306
    Suzuki 800 Intruder
    Got a friend who picked up a 1999 Suzuki 800 Intruder/Volusia V twin. His fiance is riding it as her first bike, and it did well for the first couple weeks, now it's putting out a lot of smoke from one cylinder when first starting out and once she's past second gear it diminishes to where it can't be noticed.
    The bike sat for a couple years before he bought it, and I'm thinking either a valve stem seal or ring.
    It did not have the problem initially, I got to ride it right after he bought it and it was doing fine at that point.
    What do you all think?
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
  • mitch
    • Oct 2002
    • 934
    Smoke
    First thing i would do is check the oil , if the carb floats are sticking then it might of filled the crankcase over full causing it to smoke.Also you might do a compression test to see if that cylinder is down on pressure . Just a couple things to check. Good luck
    Doug
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
      • 3306
      Thanks for the ideas, I'll pass it on. I'm guessing a stuck ring myself, since it ran well and then just one cylinder is having the problem.
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
