I am in the process of resurrecting/reviving a yammy XJ400 which has crank bearing issues.. Now i've always heard the Piston rings are better off if not taken out of the cylinders while dismantling the engine by lifting the cylinder enough so that the Circlips can be removed & with it the piston pins (It used to be a pain but do-able on 2 Cylinder engines but i'm not sure if its possible on a 4 Cylinder engine)
Now my question is, Since the Plugs were light tan & the Compression was good prior removal.. do i need to keep them in the bores for a possible re-use of the rings?
