Yamaha Final (shaft) Drives
  • Brian_D
    • 355
    • Gardner, KS
    YAMAHA FINAL (SHAFT) DRIVES
    FINAL DRIVES.......YEAR/MODEL........................RING/PINION.....NOTES
    5JW-W4612-00-00....03-05 FJR1300.....................33/9, 3.667.....2,6,8
    3P6-W4612-01-00....06-up FJR1300.....................33/9, 3.667.....2,6,8
    1FK-46101-01-00....85-95 VMX1200 V-Max...............33/9, 3.667.....2,5,9
    1FK-46101-02-00....96-97 VMX1200 V-Max...............33/9, 3.667.....2,5,9
    1FK-46101-10-00....98-up VMX1200 V-Max...............33/9, 3.667.....2,5,9
    4R0-46101-00-00....82 XJ1100......................33/10, 3.3......1,4,7
    4H7-46101-00-00....80-81 XJ650.......................32/11, 2.909....3,5,9
    5G2-46101-00-00....82-83 XJ650.......................32/11, 2.909....3,5,9
    5G2-46101-01-00....85-86 XJ700 Maxim.................32/11, 2.909....3,5,9
    5G2-46101-00-00....81-83 XJ750.......................32/11, 2.909....3,5,9
    31A-46101-00-00....83 XJ900.......................32/11, 2.909....3,5,9
    2H7-46101-00-00....78-80 XS1100......................33/10, 3.3......1,4,7
    4R0-46101-00-00....81 XS1100......................33/10, 3.3......1,4,7
    1J7-46101-N0-00....77-79 XS750.......................32/11, 2.909....2,4,8
    3J2-46101-N0-00....80 XS850.......................32/11, 2.909....2,4,9
    4R2-46101-N0-00....81 XS850.......................32/11, 2.909....2,4,9
    5G2-46101-01-00....84-85 XV1000 Virago 1000..........32/11, 2.909....3,5,9
    56W-46101-02-00....84-85 XV1000 Virago 1000..........32/11, 2.909....3,5,9
    56W-46101-02-00....86-99 XV1100 Virago 1100..........32/11, 2.909....3,5,9
    2NT-46101-00-00....87-88 XV535 Virago 535............32/11, 2.909....A
    2NT-46101-00-00....90 XV535 Virago 535............32/11, 2.909....A
    2NT-46101-00-00....93-00 XV535 Virago 535............32/11, 2.909....A
    5G2-46101-01-00....84-85 XV700 Virago 700............32/11, 2.909....3,5,9
    5G2-46101-01-00....88-97 XV750 Virago 750............32/11, 2.909....3,5,9
    5EL-46101-00-00....99-up XVS1100 V Star 1100.........32/11, 2.909....3,6,9
    5FB-Y4617-00-00....98-up XVS650 V Star 650...........32/11, 2.909....A
    26H-46101-01-00....83-85 XVZ1200 Venture (Royale)....33/10, 3.3......1,4,7
    1NL-46101-00-00....86-93 XVZ1300 Venture (Royale)....33/10, 3.3......2,5,9
    4NK-46101-00-00....96-97 XVZ1300 Royal Star..........33/10, 3.3......2,6,9
    4YE-46101-00-00....98-00 XVZ1300 Royal Star..........33/10, 3.3......2,6,9
    4XY-46101-00-00....01-up XVZ1300 Royal Star..........33/10, 3.3......2,6,9
    Notes:
    1. fully splined pinion coupler
    2. recessed splines on pinion coupler, drive shaft spacer required
    3. unknown if pinion coupler is fully splined (recessed splines probable)
    4. final drive shock mount
    5. final drive shock mount relocation or R1 mono shock required
    6. no final drive shock mount, R1 mono shock mod recommended
    7. no pinion coupler oil passages
    8. pinion coupler oil passages, RTV and washer required
    9. unknown if pinion coupler oil passages exist (oil passages probable)
    A. final drive pinion coupler not compatible with XS1100 drive shaft
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    ouch
    Info overload. seriously xselent research. I have a few shaft length measurements...And more coming from the bay...We should add these to the list here?...awesome work Brian...Chop
    MDRNF
    79F.....Not Stock
    • Brian_D
      • 355
      • Gardner, KS
      took a while to find the ring/pinion ratios.
      shaft info much more difficult to come by but yes definitely need to add...would also like to add pertinent info on selected swingarms - Virago, V Star, Royal Star.
      • Brian_D
        • 355
        • Gardner, KS
        oh yeah, if you know how to format the table so it doesn't dance all over the screen, feel free to repost.
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          shafts
          I THINK THE 1980 XS850 SHAFT COULD BE A HOLY GRAIL OF SORTS BECAUSE I SAW ONE THAT WAS ON THE BAY WITH THE XS11 YOKE SPLINES "LOOKING" THE SAME....BUT THEN AGAIN I THINK THE COUPLER SPLINES ARE JUST LIKE THE THINNER XS750 SPLINES....WOULD BE CURIOUS TO KNOW FOR SURE....
          MDRNF
          79F.....Not Stock
          • Brian_D
            • 355
            • Gardner, KS
            Re: shafts
            Yep, yoke splines are definitely the same as the XS850 uses THE SAME U-JOINT as the XS1100
            guessing the shaft splines for the coupler end are thinner on the "recessed" models due to the fact that they are constantly lubricated with final drive gear oil. ie: recessed pinion coupler splines = pinion coupler oil passages. appears that the XS/XJ 1100 and the 83-85 XVZ1200 Venture (Royale) where the only shaftys in Yamaha's stable that DID NOT have the recessed splines and oil passages.
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              splines on couplers
              When I researched the xs11 to xs750 FD swap, I found that the coupler to pinion splines had different numbers as well. This would also be interesting info to know because if the coupler could be swapped from any other FD we wouldn't even need a spacer?????
              MDRNF
              79F.....Not Stock
              • Brian_D
                • 355
                • Gardner, KS
                pinion couplers
                don't have the spline numbers but don't have to look at many......
                PINION COUPLER.....YEAR/MODEL
                4H7-46123-01-00....03-xx FJR1300
                3P6-46123-01-00....06-up FJR1300
                4H7-46123-00-00....85-95 VMX1200 V-Max
                4H7-46123-01-00....96-97 VMX1200 V-Max
                4H7-46123-00-00....98-up VMX1200 V-Max
                2H7-46123-00-00....82 XJ1100
                4H7-46123-00-00....80-83 XJ650
                4H7-46123-00-00....85-86 XJ700 Maxim
                4H7-46123-00-00....81-83 XJ750
                4H7-46123-00-00....83 XJ900
                2H7-46123-00-00....78-81 XS1100
                1J7-46123-Y0-00....77-79 XS750
                3J2-46123-00-00....80-81 XS850
                4H7-46123-00-00....84-85 XV1000 Virago 1000
                4H7-46123-00-00....86-99 XV1100 Virago 1100
                4H7-46123-00-00....84-85 XV700 Virago 700
                4H7-46123-00-00....88-97 XV750 Virago 750
                4H7-46123-01-00....99-up XVS1100 V Star 1100
                2H7-46123-00-00....83-85 XVZ1200 Venture (Royale)
                4H7-46123-00-00....86-93 XVZ1300 Venture (Royale)
                4H7-46123-01-00....96-up XVZ1300 Royal Star
                I did not include the Virago 535 or the V Star 650 as they used a completely different driveshaft design on the fd side.
                wonder if the 2H7 coupler from the XS/XJ 1100 would be straight swap for the drives using the 4H7 coupler?
                • randy
                  • Dec 2003
                  • 4521
                  xschop,
                  When i did my 750 FD swap, I got both the 850 and 750 shafts to compare. Niether would work. 750 was too small diameter at the u-joint end and 850 was too short. i did the mod with the copper pipe spacer.
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    850 shaft
                    did the 850 shaft have the same YOKE splines as the xs11, unlike the 750? I believe the shaft changed one of the years of the 850 but not sure....chop
                    MDRNF
                    79F.....Not Stock
                      The older 750's used a type of CV joint in front instead of a U joint, that is why the OD of the shaft is smaller at the front. Last month when trbig and I did his FD swap, it came with a D/S still attached, and it was the smaller diameter shaft at the front.
                      • Brian_D
                        • 355
                        • Gardner, KS
                        XS850 drive shaft
                        Randy, do you still have that 850 drive shaft? the yoke end should have the same 21 splines as the XS1100 shaft as both bikes use the same yoke.
                        According to Yamaha's web site, the '80 and '81 850 shaft is the same p/n. Interesting that it is shorter than the XS1100 shaft. Would like to know its length.
                        • MAXIMAN
                          • Jan 2005
                          • 1817
                          Just FYI
                          I bought a brand new (NOS) 1979 XS750 final drive at Speed and Sport today for $260. They only had one so I snagged it.
                            Why did you buy a new one? Something wrong with the one you put in?
                            • randy
                              • Dec 2003
                              • 4521
                              Brian_d,
                              Yes, the yoke splines on the 850 and 1100 shaft are the same as is the yoke itself, but i mocked up the drive assembly and the 850 shaft was way too short for the 1100 swingarm.
