The alternator system on the 400 is a lot like the one on the 1100. 3 windings, each leading to the rectifier.
I just put a second rotor/stator on the bike, and still I get no charge. I have yet to change out the regulator or rectifier. Looking at a few on Ebay. The rectifier checks ok with a meter. I'm even considering wiring in the spare 1100 rectifier/regulator I have. It looks like it would be straightforward enough.
Shouldn't I see some sort of ac voltage on any of the 3 rotor leads when the bike is running? I have verified the field coil is getting 12V when the bike is running. I am not seeing either AC or DC of any sort either metering across the alternator coils or with respect to ground.
I ohmed out the coils on both stators and field coils and they are all pretty close to spec, being 1 ohm when it's supposed to be .7. My meter leads ohm out to .2 by themselves. Will a difference that small be too much?
Both alternator units measured almost exactly the same, which I why I suspect something else.
Any help would be much appreciated!
