can someone measure the mounting hole to mounting hole distance on a xs650
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    is it46mm thanks
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Which mounting holes are you talking about?
      • 8022
      I have a couple XS650s on hand. I can measure anything you want. I just need to know what it is you want measured. It will likely be tomorrow before I can do it.
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        duh, sorry, fuel petcocks, wonder if the xs650 petcocks will plug and play on the xs 1100.
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
          • 8022
          XS650 petcocks -NO GO
          No. The XS650 petcocks will not interchange with the XS1100. They are bigger. I learned this from a single petcock equipped XS650.
          Since may curiosity was aroused, I dug up an earlier tank equipped with two petcocks. They won't work either as they are a match to the first one I checked.
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            from what i read on mike's xs, is that they went from 2 to a single vacuum petcock in 1980 and they have a manual replacement,
            with an overall small profile i'd say compared to my xs 1100's they are half the size, all i need is the mounting hole to
            mounting hole distanse in mm to see if mike's aftermarket manual replacement will screw in, i'll take the heat if it does not fit and you all may benefit...
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              btw does the later tank with just the one petcock have a balance tube to capture gas from the right side? thanks
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
                • 8022
                There is no balance tube in the single 650 petcock. The mounting holes are not spaced the same as the XS1100. I have the XS650 Special parked right beside the XS1100 Special. I also checked two other XS650 fuel tanks. MIKES isn't going have the petcock you need
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  sad indeed, thanks anyhow
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    c'mon, i'm still not convinced, 78-84 xs650 petcocks were vacuum, the one's on my xs1100 hit the airbox and carbs like diverray's ised too.
                    i have a very big suspicion they are xs650 oem, and looked in ebay to verify, they look the same, mounting hole to mounting hole distance in millimeter please. for the 79 thru 84 xs650
                    anybody, a breathing, pulsing body?
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                      • 8022
                      My XS650SK (1983) has a vacuum petcock. There is no "OFF" position on it. It has "RES", "ON", and "PRI". It doesn't look much like the one on my XS1100SG. It is physically bigger.
                      I'm away from home and I can't get a look right now.
                        • 8022
                        I should mention that I bought my XS650 new from the dealer back in 1983. It still has the original petcock.
                        • mason79
                          • Mar 2006
                          • 1359
                          • los angeles, ca
                          if you stumbled on to my thread on the other board, i know they are bigger, i just need the mounting hole to moiunthing hole distance and that is all,
                          forget everything else, size, years looks, forget it ....just the measuring and thanks a mil!!
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                          • mason79
                            • Mar 2006
                            • 1359
                            • los angeles, ca
                            yes they are exactly the same as the xs1100 79 holes
                            jetmechmarty wrote on 03-27-2007 07:24 PM:
                            I measured about 1.781 inches or 45.24 mm center to center on the mount holes for the XS650 petcock. 52.4 mm between the outside edges of the mount holes. How exact do you need me to be? I'm pretty close, but I just finished a 12 hr shift. I could send you a rubbing if it will help. I can send digital photos too. 12 hr shift again tomorrow.
                            Marty
                            mason79 wrote on 03-27-2007 09:27 PM:
                            hey buddy any chance to grab that measurment? thanks
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
