Gmc 454
  • mro
    • 4276
    • Hayward, California
    Let's see.... 50,000 miles at 4 to 5 miles a gallon.... lol.
    Mines got 240,000+
    Once upon a time it got 14mpg on the high way with light loads and just about 12 pulling a trailer. Now lucky to get 10 with a tail wind.
    mro
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      WEll, towing a 10,000 lb travel trailer it gets 7-8 mpg. With big bias ply tires, and the standard rear end, It does well. The dealer wanted my dad to get the lower ratio rear end, that would kill milage. With a 454, you don't really nead the lower differential. I am looking into some good headers that was on my friends chevelle SS454, but that is my last option. This is now getting put on the back burner because of some sensor problems screwing up fuel delivery. Maby the CDI is bad or something. I have a chiltons for it, but it does not cover everything. The other day, one of my dad's 79F's lost ignition on the inner spark plugs. It is probalby a pickup coil, but I have soo many things to do this weekend, and finals are next week, I won't have time for a while to work on the truck. I am putting all of these ideas together and trying to form some conclusions on the best way to handle this truck. I was going to get the engine running properly and polish the whole truck as my Dad's Christmass presant, but just getting him an XS11 hat is much easier. I haven't even been able to find out if the stock manifolds are available. I was also wondering about the manifold bolt pattern. Are there any differences between a early 70's 454 and a ealry 90's? It is basically the same as the 88-89, but with the new TBI.
      Acta Non Verba
      • RUSH
        • Feb 2005
        • 214
        • Lake Stevens, WA
        I wouldnt get SS bolts if I recall correctly they dont have the strength of even standard bolts. if you are going to change them go for the hi tensile bolts.
        First bike was an: 1978 XS1100
        Second bike is an FJR1300.
        Now I'm restoring a '79 XS1100.
        • mro
          • 4276
          exhaust
          The stock cast iron manifolds are prone to cracks. If yours are still good the gasket should take care of leek. Have talked to some RV guys (454 was popular) and cracks in stock exhaust manifolds was said to be common.
          If I decide to keep mine, may buy a new long block from the local GMC truck center along with steel exhaust manifolds. Other option is getting a diesel. Fuel cost more but better milage.
          fuel delivery
          If you have the "throttle body fuel injection" may want to pull injector out and make sure it's clean. Some can be disassembled and there should be a fuel screen. Also check fuel pressure. Just because you can hear the fuel pump don't mean it's working properly. The computer can go bad but not as common as other problems.
          mro
          btw
          Merry Christmas
          • HobbyMan
            • 1801
            • Colleyville, TX
            I took both injectors out and cleaned them the other day. It is still struggling a bit. The TCI went bad already once before. The unit that is in there now is a rebuild one that was done by a company in FT. Worth, I think. It could just be a sensor.
            Acta Non Verba
            • Sluggo
              • Nov 2006
              • 5
              • Broomfield, Co.
              Naturally, you used the A.L.D.L to pull the codes from the computer. This would be the wisest way to proceed. There are a ton of sensors that could cause the vehicle to run poorly. If your Chilton manual doesn't give you the needed information and flowcharts to figure out the problem, may i suggest making a stop at your local library and see if they have better manuals. You may not be able to take the book home but you can copy the pages that show you the procedures.
              By the A.L.D.L., i mean the terminal under the dash board that you stick the 2 pronged tool [ or piece of wire] into and count the "check engine light" flashes. this gives you a code of what the computer sees as being out of whack.
              Good luck
              "I almost forgot, I used to be a wrassler"
              "I aint got time to bleed"
              • HobbyMan
                • 1801
                • Colleyville, TX
                I have the code reader. i thought It only worked when the engine light was on?
                Acta Non Verba
                • goldcoastguy001
                  • Dec 2006
                  • 137
                  • Gold Coast, Australia
                  I raced a 77LT camaro for 7years with a 454cu, had headers on it but I can say for sure that S/S bolts are a waste of time....they heat up to fast and cool too quickly for the head you will end up having to tighten bolts every other week.....change the gasket with a good alu/fibre gasket and H/T bolts and tighten the hell out of them you wont have any problems after that I can gaurantee it. also make sure timing is correct flames out the exhaust is a sign of to much advance on the timing....big blocks generally wont ping with too much advance unless it is really advanced just a side note they run exceptionally with vacuum disconnected and timing static set at 38-40degrees....the springs in the dizzy advance mech lose tension and advance it prematurely........
                  1982 XS1100R
                  1982 XJ650
                  1983 VT400
                  1990 XVS Shadow
                  1983 Z1100
                  -I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.
                  • dpotter58
                    • Aug 2004
                    • 1852
                    • Southern Maryland
                    "Yeah, I have heard from a number of peple now that have had cracked heads"
                    You'll find a few on here like that but most of us are OK...
                    1980 LG
                    1981 LH
                    • planedick
                      • Mar 2005
                      • 2068
                      • Yorba Linda, California
                      Gaskets?
                      After replacing an engine in a chev van and the shop put gaskets on the exhaust manifold. Whoa, the dealers all tell me that is the reason the manifold cracks or warps. Chev (GMC) engines haven't had exhaust manifold gaskets since they came out with the 283. WWAaaaayy back when. Check with your local GMC dealer.
                      Drilled airbox
                      Tkat fork brace
                      Hardly mufflers
                      late model carbs
                      Newer style fuses
                      Oil pressure guage
                      Custom security system
                      Stainless braid brake lines
                      • goldcoastguy001
                        • Dec 2006
                        • 137
                        its not really gasket of sort more like like a thin shim type gasket for lack of a better word.....normally like tin type stuff...you can get a alu "gasket" for it...(bit like the inlet manifolds use to have..)
                        1982 XS1100R
                        1982 XJ650
                        1983 VT400
                        1990 XVS Shadow
                        1983 Z1100
                        • planedick
                          • Mar 2005
                          • 2068
                          No gasket....
                          No gasket is better as the engine soaks up the heat so the headers don't overheat and distort or crack....
                          Drilled airbox
                          Tkat fork brace
                          Hardly mufflers
                          late model carbs
                          Newer style fuses
                          Oil pressure guage
                          • HobbyMan
                            • 1801
                            • Colleyville, TX
                            FINALLY got around to getting this truck running last weekend. New plugs and starboard manifold. We were going to opt for a good set of headers but none will fit. Manifold was our only choice. The TBI is now freshly rebuilt and all that is left is to check some of the wiring. We put the original MC which we rebuilt a year or two ago. The cheap replacement finally gave out. My Dad is using this truck to get our excursion back from Colorado. We'll see what kind of mileage it gets with this new ethanol gas. Probably really low. Other than a little exterior polishing, this truck would make a good magazine cover. I am glad to say that it gets more complements than any of our XSs. They also come from a much wider range of people. What can you expect from a pre '88 body style 91'GMC dually pickup? IMHO, the last vehicles that came close to it were the 7.3DL '02 F350s.
                            Acta Non Verba
                            • Crazcnuk
                              • 2980
                              • Hinton, AB, Canada
                              "Let's see.... 50,000 miles at 4 to 5 miles a gallon.... lol. "
                              My 502 (Gen VI Chev big block) gets 14mpg, with 3.70 gears and no overdrive....
                              '05 ST1300
                              • HobbyMan
                                • 1801
                                • Colleyville, TX
                                I think we got around 7 mpg towing 4-5 tons worth of trailer and excursion.
                                Acta Non Verba
