I had a Matco tools rechargeable wire-feed gassless mig welder given to me, I thought "cool"-the only thing is the batteries inside wont hold a charge I was told.
So without tring it since I figured the batts were dead and figued they knew what they were talking about, I took it apart and accessed the two 12 volt batteries.
They look just like a motorcycle 12 volt battery, but they are sealed, and so I can add water to recharge them or see how low the cells are, so anyway did a search on the battery part #, and found a site where they are $31.00 apiece, well that wouldnt be too bad for a good portable mig welder, but I also checked the a/c adapter that says it puts out 24V, and it accually puts out 32 or 36, my meter said a couple diff readings with it plugged in, so I was wondering if that would be ok to put out that many volts, or is that what killed the batteries?
any help would be appreciated, thanks in advance.
I'm going to take these two batteries and try to charge them somewhere since I dont have a charger (more $!) anyway, I'll let you all know if they hold a charge, but I'm doubting they will.
I'll check back for any replies, esp. about the adapter,
Thanks in advance.
John
Thanks in advance.
John
