Filter for each carb
  • mike nich
    • Jan 2006
    • 6
    If I use the 4 small air filters for my cars
    1. What do I do with the 3 hoses that come off my air box?
    2. Is there any problems that Ineed to look out for using these?
  • 81xsproject
    • 3185
    • Fortuna, CA
    fisrt we need to know what year bike you have. Because, if it is a 78-79 you need to have vent hoses frome the carbs, the 80's don't have that. As for the two that come up off the case, I got a small air filter to put at the end of the big one and just run the smaller one up between the battery and the fuse box. I'll take a pic later.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • mike nich
      • Jan 2006
      • 6
      Its a 79
      • GNEPIG
        • Apr 2005
        • 1657
        • fl
        .. the two small hoses that come from the carbs are vent hoses, you can just leave them hanging out of the way but DONT plug them up!. the big one is for crank ventalation, some people plug a small air filter into the end of that hose, but you can route that hose out of the way also and not worry about it..
        .. since you have changed your air filters you will have to change your jetting also. do a search and you will find every thing you will need to know about that stuff also
        hope this helps
        • bandet01
          • 698
          • connersville indiana
          i have filters on each of my carbs and i like it and i never had to rejet my bike i must have got lucky but after all the stuff i am doing this winter i am going to have to rejet the carbs and try to get all the power out of the bike i can
          do not block off the hoses just route then out of the way or get small filters for them
          79 yamaha xs1100f standard
          best 1/4 mile 13.282@99.40
          • xs650mike
            • 1286
            • Lake County, California
            Don't leave the crankcase breather hose open, put a filter on it or you'll be sucking dust from the atmosphere into the crankcase, the vent breathes both ways.
            Shiny side up,
            650 Mike
            XS1100SF "Rusty", runs great, 96k miles
            XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
            Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
