Replacement Fuse Blocks and Possibly TERMINALS
    How thick is your cable?
    Hey Dean,
    The ATC fuses are correct! They are full sized, not the MINI fuses!
    I tried finding my 1/4" female clips, but couldn't find the box. The turn signal wire looks pretty thick, possibly 14ga, I think the other thinner ones are around 16ga, but don't know for sure, perhaps one of the electrical gurus can chime in?
    • DeanR
      • Jan 2005
      • 1490
      • Finger Lakes NY
      The fuses I got fit and look right, but they say ATO. not ATC.
      Are the the same thing?
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        You say Potato!
        Dean,
        According to my electronics parts catalog, it uses ATC and ATO interchangeably, and the holders says things like for
        ATC/ATO type fuses!! The smaller ones are called Mini, and the glass ones are AGC. SO..you're good to go!
        Also, the range of sizes for the clips appear to be rated like 14-16 range, and I would think that they would be good!
        • GNEPIG
          • Apr 2005
          • 1656
          • fl
          #34
          .. i measured the wires this morning, looks like the small wires might be 20 gauge and the large might be 14 gauge
          • DeanR
            • Jan 2005
            • 1490
            • Finger Lakes NY
            #35
            thanks guys.
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • DeanR
              • Jan 2005
              • 1490
              • Finger Lakes NY
              #36
              The new block just misses the two stock mounting screws on the metal plate by like 3/8 inch. Anybody figure an easy way to get it mounted up?
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • Jdwags
                • 232
                • Rathdrum, Idaho (nort of Post Falls)
                #37
                fuse boxes
                Still have any? Its starting to get nice and life seems to be calming down again a bit..
                Course when the 9 yr old is sitting on the bike asking when im gonna put it back on the road... that does help with the motivation
                BTW, hi everyone, im back in a limited capacity- life has been pretty rough the past 2 years.
                jeff "Wags"
                Bothell, Wa
                79sf mongrel
                79sf rusty
                79 partsbike almost complete
                  fuse block
                  Yeppers Laxdad...........don't have any pics, but you'll see that the two holes on block are offset. Make the left side hole an open slot witha dremal cut-off wheell or hack saw blade. Go above the existing hole on right side of fuse block,to a point straight across left side hole and drill new hole. Remove your existing fuse panel, leaving wires attached, pulled to one side. Mount new fuse block using your same screws and add a flat washer to each. Clip each wire close to old crimp of fuse holder and use 90 degree blade ends so wires come out toward you, not vertical. Plug on each one as you go. Run the wires for the lower connections to the front, down around the front side of new fuse panel. This will keep you from having to find some slack in the harness. after having all wires hooked back up, use three small plastic wire ties to attach lower wires in a small bundle. Also put a small dab of dielectric silocone compound(from your local auto-parts store) on each connection and fuse before plugging them in. The job completed like explained will look very professional and that part of electrical system will be trouble free.
                    fuse block
                    One more thig Laxdad..........The hole thats redrilled WILL come close to edge of new panel. You'll find the quality of base is fairly dense and hard and having hole close to edge won't be a problem. This will give you the distance between holes that's needed, and leave enough of slotted side to hold well with the small flat washers. The square opening of base plate won't be totally covered, but wiring harness covers most of opening , and isn't noticed anyway. All done, it'll look like it was original to any who aren't observant XS'ers...........Happy mounting!
                    • DeanR
                      • Jan 2005
                      • 1490
                      • Finger Lakes NY
                      #40
                      Hi Motoman, thanks for the quick detailed response! I'm sitting here with the mounting plate in my hand ready to drill. The hole that is required is Right Next to the edge of the metal plate and there is the circular raised area with the integral nut on the backside that makes matters a little worse for drilling. Should be obvious and easy but can't quite visualize where to drill! Duh.
                      Wish I had a digital camera for a pic worth a thousand words.
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
                        Don't drill re-drill the plate!...Drill the new fuse block as I stated. re-read and you'll understand. If not, let me know here or IM....I'll get ya lined out.
                        • DeanR
                          • Jan 2005
                          • 1490
                          • Finger Lakes NY
                          #42
                          Plastic is drilled and dremelled. All mounted up straight and tight. Now just have to cut perfectly good wires! Thanks for the advise.
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
                            Anytime Laxdad............That was the simplest remedy to mounting for me. More time consuming, could've cut thin aluminum plate to cover opening using the original screws and holes, mounted using plastic spacers for space to put nuts on backside of new mounting holes for new style fuse block. Figured that was a bit overkill, and this mounting style looks good. The key to a nice look anyway is using 90 degree crimp on connectors.........Sounds like you got it all under control.
                              #44
                              Update on Availability!
                              Hey Folks,
                              I had sold the last of the last batch of fuseblocks a few days ago, and placed an order Saturday for more! I just got a message from DelCity that they are currently out of stock, and gave me an estimated 4-6 weeks before they expect to get it back in stock!
                              I had 2 left over that I was keeping back for my BasketCase and my other chain drive project, but with this development, I'll be happy to let them go to those more needy!!
                              So....BlueJeepLab/Papa Gino had contacted me first, and I'm holding one for him. Recently both RIdinhi, and Mudbuddy stated a need for one, but alas I only have 1 left. I'm not trying to start a war, just want to be fair in providing it to the next First Come, First Served!
                              For the loser, it is available from several other sources, albeit at a bit higher price, but if you really need to get it ASAP, there is a way! Again, apologies for this situation, didn't know they would run out!?!?
                              • oldbiker648
                                • Jul 2003
                                • 182
                                • Richmond, VA
                                #45
                                Hey TC,
                                Put me down for 3 fuse blocks and I can wait the 4-6 weeks no problem. Thanks from the entire list for finding an upgrade which most of us need and then taking the time to confirm that it is the correct product and making it available at a reasonable price. You are one of the guys who just seems to go the extra mile for the rest of us and I want you to know that your efforts are recognized. Let's get together before W VA.
                                _________________
                                John
                                78E
                                79 SF (2)
                                80 G "The Beast"
                                81 H "The Dresser"
                                79 XS650 II
                                82 650 Maxim
                                70 DT-1 Enduro
                                66 Honda CL-77 Scrambler
                                96 H-D Road King
                                "The road to hell is paved with good intentions."
