Shocks Question
  • 81xsproject
    • 3185
    • Fortuna, CA
    Shocks Question
    I want to raise the rear a little and was wondering what other bikes would have a little (13-13.5") longer shocks that are heavy enough for our old tanks.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • strom
    • 1577
    • Slovenia, EU
    V-Max shocks... maybe some konis.... I know V-max has bout 15mm longer shocks. I have them installes, they are great for solo riding, but a bit soft for two-up. But then again, I'm a heavier set guy
    LP
      • 7786
      I run progresive shocks on my '79. They are 13.5", made for a BMW, and do cause the bike to LEAN on the side stand. they came with the heavy springs, and work great. give me a little more lean angle in the corners. I don't remember the exact model #, but I know they are still easily available. Just get the heavy springs with the shocks, and your good.
      Ray
      • Street_Rat78
        • Sep 2005
        • 253
        • Columbia, SC
        Another Question...
        ((If sitting on the bike)) my left shock has no bolt through the top hole. I got to looking at it, and I can plainly see where it has been sheered off. Now the question is ... what is that bolt/shaft/threaded rod connected to? What do I need to replace so I will be able to bolt down the top of my left rear shock???
        Any help would be fan-tab-ulous.
        ~ Street Rat ~
        Mitch
        '78 XS1100 "My Mistress"
        Knowledge is Experience. Everything else is just Information
        • mro
          • 4276
          • Hayward, California
          yamaha-motor.com/sport/parts/home.aspx
          if link above works, diagram shows 78 frame (rear shock mounts same as my 80G. No separate part# for stud so it is probably welded in place.
          May need to grind/cut remnant of old stud out and weld in a new one.
          mro
