I read a little about the uses of Star Brite Liquid Electrical Tape but I just don`t know enough about it. Other than water proofing electrical connections can one use it to seal cracks in rubber intake boots-- from airbox to carb and what else? I have a can of it and would like to know from people who use it roughly what all you can use it for. Will it work in cold weather? Some advice and tips. Thanks.
liquid electrical tape
I've used the stuff for several years. Have not applied it in cold weather, but use in cold weather is fine. Stuff does not crack or peal.
Like bondo and sheetrock mud, trick is to put on a few thin layers, let dry between applications. A small paint brush, used to paint model cars and such, works well as an applicator.
I use the Liquid Tape when I can't get heat-shrink tubing where I need it, and only use electrical tape as a last resort or temporary solution. Have not tried the 'bonding' electrical tapes now on the market, sounds like a good idea.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
Heat Shrink...
I've never used the liquid tape before, but I have used Heat Shrink, and I'm not a huge fan of it. Don't know if I'm just not shrinking it right, or whatever, but it never seems to work too well for me. It's either too lose or lumpy, or burnt and blistered.
Then again, maybe I'm just too picky.~ Street Rat ~
Mitch
'78 XS1100 "My Mistress"
Knowledge is Experience. Everything else is just Information
The part I`am wanting to fix needs to be removed first and right now it is to cold to do so. I will fix a lot of things with this stuff when it warms up. It might work fine in cold weather but I don`t . Thanks for helping out.Bill Harvell
Re: to cold?
Originally posted by valhallan
since when is it ever to cold? thats what living rooms are for! and an XS makes a wonderful addition to just about any room in the house. mine is in the basement right now.Bill Harvell
Re: to cold?
too cold?
What's too cold??
Yall don't work when it cools off?
Thought you guys out in the Carolina's had mild weather with a little warmth blown in from the gulf now en then.
Did get a little cool here last night, had to be down to a least 50
Would be out right now but had to bring my daughter home from work and some shopping.
mro
Tubing will shrink down to the wire, and if your connection is lumpy the finished product will be as well. One solution is to put a 2nd layer of shrink over the first; this will help make a better-looking connection. Remember to cut the 2nd piece longer and overlap both ends of the first if possible so the final joint looks like only 1 piece of shrink was used.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
Re: Heat Shrink...
Liquid electrical tape is great stuff for electrical connections. Work well for the designed porpose...highly recommended!Gary Granger
