Comfirm torque specs for motor mounts
  • Hawkinspickle
    • Feb 2022
    • 82
    • British Columbia Canada
    Hi folks,
    Just installed a 1980 motor into my 79 frame. It all fit perfectly except I need to confirm the following torque specs. Any help would be much appreciated as there seems to be some contradictions between my Clymer manual for a ’79 special and a Yamaha service manual for the same year. For example, the manuals seems to conflict for the 4 bolt connecting the drive flange u-joints. One said 79 Ft. Lbs and the other 31 Ft. Lbs. I figured the 31 was correct. Weird? Can some please confirm the following torques (see attached) for the motor mounts as shown. Hate to bugger them up!
    Thanks all,
    • 833
    I'd go with what the Yamaha manual calls for before Clymer.
      • 8928
      From the Yamaha Service Manual...
      Front engine mounting bolts upper and lower 48.5 ft/lb (10MM bolts)
      Rear engine mounting bolt 72.3 ft/lb (12MM bolt}
      U-Joint 31.8 ft/lbs
      • Hawkinspickle
        • Feb 2022
        • 82
        Thank you gentlemen. The Clymer manual I have is way off then. So when you say upper and lower mounting bolts Bikerphil, you mean #2 and #4 on my picture, not #3 which do not have any torques specs. The manual talked about "through bolts" being 72ft/lbs which #1 and #2 are. ...but it appears that only #1 should be torqued to 72ft/lbs.
        Dan
        • Hawkinspickle
          • Feb 2022
          • 82
Name:	torque specs.JPG
            • 8928
            #1- 72 ft/lb
            #2,3,4- 48 ft/lb
            The front thru bolt is smaller diameter than the rear, that is why it would be 48
            • Hawkinspickle
              • Feb 2022
              • 82
              As an aside, looking at a few posts and Bikerphil’s response to me, I just noticed my faux pas in terminology, i.e., motor vs engine. While people use both interchangeably, the difference is that motors run on electricity and engines run on combustion. I now know better.
                • 7828
                Actually, I was told in school years ago that a motor is self starting, and an engine needs something to start it turning. But, we're splitting hairs at this point! I hope you get that engine/bike running soon. The wet and cold is on it's way.
                  • 8928
                  Well. It's called a motorcycle for a reason, because of it's motor, right?
                  • red bandit
                    • 970
                    • central michigan
                    I was told 45 years ago that a motor is an electric motor. An engine is a gasoline engine. I'm just glad it goes varooom.
                    79 SF parts bike.
                      • 8928
                      Don't forget about the original engine powered by steam.
