79 3H3. Carburettor main nozzle (aka. emulsion tube / needle jet)
  • wbw750
    • Jun 2021
    • 15
    • Cheshire England UK
    Hi from UK
    I've tried a few Facebook sites, with limited success to resolve this issue .....
    The Parts List for 1979 Eleven Special 3H3 shows 2 different main nozzles as photo (Yamaha description), ie. 2 pairs
    One pair for outer carbs 1 & 4: part no: 2H7-14941-02
    One pair for inner carbs 2 & 3: part no: 3H3-14941-02
    So one pair has 16 cross-drilled holes, and the other pair 12 (maybe 10). It's not clear in the book how many holes each type had.
    My operation assumption is:
    The fuel (gas) goes up the tube via the main jet, while air whistles in via the cross-drilled holes to emulsify the fuel (the holes are well above fuel level)
    So, my question is.... do the ones with more holes go in carbs 2&3 (i.e. let more air mix with fuel to give a cooler burn for the middle cylinders), or not.
    All opinions advice welcome?
    thanks
  • red bandit
    • 970
    • central michigan
    The ones with less holes go in 2-3. Less air holes makes it richer. Richer is cooler.
    79 SF parts bike.
