YamaBond on diesel fuel tank
  • red bandit
    • 951
    • central michigan
    My diesel fuel tank on my tractor has a pin hole in it. Will YamaBond hold up to diesel fuel? Anybody know?
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
    • 7738
    JB should hold up. Yamabond works between two parts, but probably would leak on the tank. There is a gas proof weld available at auto part stores that would also work.
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      I have used Seal All. It is fuel proof. It's in a yellow tube, and readily available.
      79 F
      1967 Suzuki X6 Hustler
      1973 Suzuki TM 125
      1979 XS1100 F
      2005 Kaw. Vulcan VN800
      1991 BMW K75
      • red bandit
        • 951
        • central michigan
        I was thinking about brazing it but afraid of blowing a big hole. The metal is probably pretty thin in that area. Thanks guys.
        79 SF parts bike.
          • 7738
          Clean the metal well and solder up the area. I did that on an XS tank someone had botched a repair on. Use the plumbers solder kit, make sure the steel is clean, flux the area, and go easy on the heat from the propane torch.
          • red bandit
            • 951
            • central michigan
            Good idea. Thanks.
            79 SF parts bike.
