accel coils
  • accel coils
    ok i need a detailed instruction on installing the accel coil kit and i need to know what kit number you guys used
    the reason i need to know is i have heard people say do this do that and i need to know if you had to rejet your carbs when you did put the coils.
    the main reason i am asking is my brother put them on his virgo 920 and couldnt get the bike to run right after he put them on and now had to go back to stock coils and cant even use the accel coil and i dont want to be in the same boat as him
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
    Hey Bandet01,
    Have you seen this tech tip....it's for Dyna coils, but would be similar to Accel:Dyna coil Install Techtip
    As for your brother's XV920, it uses the 2.7ohm style coils, which are inductive type, but if he got coils for a CDI ignition, thinking he had that type, then they would have been 0.7ohm which are the wrong type, and probably why they don't work!?
    Our XS11's also use Inductive ignition, and so you want the higher resistance ones, 2.7-3.0 ohm style, that's about all you need to get the correct ones. I've seen the exact model numbers posted, just do a search for accel coils, you'll find it!
      Are THESE the correct coils then?
      Dennis Kirk Part #: 20265
      Manufacturer Part #: DC21
      Type - (Price)
      Quantity:
      2 on hand
      Your Price: $147.99
      79 XS1100F "JINGUS"
      07 V-star 1100
      Do you want it done right or do you want me to do it?
        Hey Bud,
        They are the correct coils, IF you want to use the 3 ohm on your machine, but you'll need to remove/bypass your ballast resistor. The tech tip mentioned that Dyna did make a 1.5ohm version for the earlier model XS11's. SO depends on which one you want to use, either the 1.5 ohm or the 3 ohm!
          Sorry about the link confusion. The first page on that website lists the DC41 coil.
          You have to hit the dropdown to access the DC21
          Your Price: $147.99
          * 1.5 ohm, 6 volt, angled dual output (use two for dual-plug applications)
          * Sold in a pair
          * Dyna Coils are the industry standard, delivering 35,000 volts with spark energies second to none
          * Made to work with all points ignitions, aftermarket electronic ignitions and most factory electronic ignitions
          * Can be used for dual-plug applications
          * Only use coils that are within 10% of the OEM coils standard resistance
          * Made in the U.S.A.
          The DC21 was actually the one I was refering to.
          79 XS1100F "JINGUS"
          07 V-star 1100
            6 volt???? Does the TCI have a regulator?
            Steve
            80 XS1100G Standard - YammerHammer
            73 Yamaha DT3 - DirtyHairy
            62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
            Norton Electra - future restore
            CZ 400 MX'er
            68 Ducati Scrambler
            RC Planes and Helis
              The Dyna coils I used in the tech tip were advertised as 6 volt. They are working perfectly.
              Pat Kelly
              <p-lkelly@sbcglobal.net>
              1978 XS1100E (The Force)
              1980 XS1100LG (The Dark Side)
              1999 Suburban (The Ship)
              1994 Dodge Spirit (Son #1)
              1968 F100 (Valentine)
                I was wondering about that too. Of the 3 Dual coil sets available which would be the direct replacement for ours?
                I'm getting a weak spark and I think my #2 plug wire is broke at the coil. I'll try the "fix" listed in the tech tips but I need to know there'll be a backup for if/when I screw it up.
                79 XS1100F "JINGUS"
                07 V-star 1100
                  Hey Bud,
                  I don't know if any of these would be considered DIRECT replacements, but the 1.5ohms are closest for your model. However it's not a big deal to bypass the ballast resistor for the newer style 3 ohm coils. Have you seen this thread, it shows info about the much less expensive dual coils from MikesXS?
                  Alternative Coils thread
                    i am going to go with the accel coils when i do put the coils on the bike and where is this resistor at that has to be byoassed to make the accel coils work right
                      I think Accells 1403's are for TCI style ignition and 1404's are for CDI style ignition. Installing the wrong coils on a TCI ignition fries the Igniter. The resistor is under the tank on the left front side.
                        so is the xs1100 a cdi ignition or a tci igniton i dont want to put the wrong coils on my bike
                        • #13
                          Bandet01,
                          It's a TCI, that's why it needs the higher resistance coils, not the CDI which uses the very low resistance coils!
                          • #14
                            hey Bandit. If you do use those let me know how it goes.
                            Also what year model is your bike?
                            Mines a 79
                            Will it be the same coil?
                            79 XS1100F "JINGUS"
                            07 V-star 1100
                            • #15
                              I have a spare stock set with good wires and plugs for ballast resister type xs1100 go ahead and try the fix. andreas
