I read the post under misc. tips for what to look for in a used bike, and what to work on before starting it up the first time, but i have some questions still. Background: the bike was left at a shop for an estimate on restoration, it was running when it was dropped off. that was 3 years ago. it has not been started since then. its a '79 XS1100SF. it LOOKS good other then rust. surprisingly all the fuel lines and cables are flexible, not dry rotted, although the brake, throttle and clutch cables are seized up.
looking over that listing on the post, i see everything i need to do (or at least start with) but, is there a BEST order to start with? obviously change/replace all fluids, but after that, then what? should i try starting it at that point or what? i want to be as economical as possible, but i'm willing to pay what i have to for this neglected beauty. i'm also stuck with a great desire to get her on the road ASAP, and at the same time wanting to get everything perfect first. With winter coming i'm resigned to not riding her until spring if neccasary, but it would really boost the incentive to work on it if i could just here her run once!
