Side cover fix?
  • piet
    • 75
    • nederland
    It's really a peace of cake!
    repare the damage with a soldergun,simply melt the torn parts thogether by pressing in between with the hot metalpoint (almost thrue the plastic but not total) and after you created a little hole you wipe material from around in that hole,and so on the whole Crack
    After the whole crack is ''melted'' away on two sides you kan start filling it up with extra plastic again melted and pushed and wiped on the repared spot so you finally only have to sandpaper it and spray primer/filler on it.
    xs1100 black 78 2h9 on the road
    xs1100 red 79 special with sidecar running on LPG and gas!
    xs1100 silber 79 2h9 o t r
    xs1100 white 80 2h9 Martini o t r
    xs1100 red 78 2h9 Martini o t r
    xs1100 black 80 special o t r
    xs1100 black 80 2h9 in parts sleeping
    xs1100 black 81sport for sale!sleeping
    xs1100 silber 81 2h9 i.p. sleeping
    xs1100black81midnspeciali.p.sleeping
    cbx1000 grey prolink 81 sleeping
    cbx1000prolink 83 in parts sleeping
    gsx750ex red 81 in parts sleeping
    • 81xsproject
      • 3185
      • Fortuna, CA
      Ok, I had another idea today. What if I was to do like I was saying before by laying the Bondo figerglass/epoxy on both sides after having drilled lots of holes through the cover so that the epoxy would be binding both inner and outer sides together? This seems like it would solve any bonding issues.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • ccogswel
        • Jun 2005
        • 302
        • Bowling Green, Ky
        I used a soldering iron. Just like piet had mentioned. My side panel had a crack about 6 inchs long. Just melt the crack back together. Do a little sanding and your done. Mine looks great! Just needs paint. I haven't bought any in some time but Ace Hardware use to sell this tip that fits into your soldering gun that had flat tips. They work great for me. Can't tell you how many things a have melted back together using them.
        Chris
        79 XS1100 Standard aka: Mutt
        Gimme Fuel Gimme Fire!
          I have repaired the fairing on SWMBO's FJ1100 by melting cracks back together, and melting a piece of heavy gauge stainless steel screen into the repair area, kinda like a bandage over the crack and apply the flat tip of the soldering iron to the screen until the plastic melts and oozes through the screen. It makes a very strong repair.
          • 81xsproject
            • 3185
            • Fortuna, CA
            The reason I want to use the fiberglass is that a piece of mine is broke off and missing. Unfortunately, I cant just solder.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
