When buying aftermarket Accel coils for the earlier models, I believe you are supposed to get the ones with 3 ohm resistance. But for the 80 and 81 models, you should get the .7 ohm ones. Is this correct?
I also thought I read somewhere that you should remove or disconnect or bypass some little stock component in there somewhere when doing this coil "upgrade."
I need a memory refresher.
stal87
81 special
stal87
81 special
