Fuel Tank on ebay
  • pathfinder
    XStremely XSive(Deceased)
    • Apr 2004
    • 483
    • Houston, TX
    Fuel Tank on ebay
    Not me but check it out $25.00 buy it now. If somebody gets it and doesn't neet the plastic trim on the neck of tank let me know.
    78XS11E
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    At least it has the key. I have 2 standard tanks and one is the 6 gallon touring tank but I don't have keys for either of them.
    I've tried everthing I can think of short of drilling and I can't get them open. The damn locksmith wants 25 bucks each to open them... sux.
    Geezer
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      What's the number(s) on the locks. Maybe a forum member has the same number and can send you a copy.....I would.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • Geezer
        • May 2003
        • 2985
        That's a great idea, I should have thought of it. I'll did them out and post the numbers...
        Tony
        • Lamric
          • 410
          • Kenley, Surrey, England
          I saved this quote to my little document of XS11 tips. Probably found it on this forum anyway !
          You can open the gas tank cap with a screwdriver! Under the front of the cap is a small piece of metal (1/2" X 1/16") that you can push in, toward the back of the cap, with a screwdriver. It helps if you push down slightly on the cap at the same time.
          Not tried it myself though.
          Brian
          XS1100 LG "Mr T", SG "ICBM" & FJ1200
          Check out the XS Part Number Finder
          Be not stingy in what costs nothing as courtesy, counsel and countenance.
          • Geezer
            • May 2003
            • 2985
            I've tried and I don't think there is any way to jimmy one open. I also have a rusted out tank that is missing the top cover over the gas cap and I used it to pratice on. I say it can't be done without F-ing it up. On the other hand, I sure wish some one could prove me wrong...
            Geezer
            • dwales
              • 119
              • Karthaus, Pa.
              The special can be jimmied, BTDT, but not the standard. The special cap sits on the tank. The standard cap is recessed flush with the tank.
              Highlander
              • Geezer
                • May 2003
                • 2985
                I concure but the down side is unless I can get keys, I'm looking at 25 bucks per to get my 2 standard tanks open.
                Geezer
                • scoobes
                  • Jun 2003
                  • 454
                  • formby,which is near liverpool england.
                  were i live i have a 20mn ride to the key shop give them the 4 digit no and ten min later i am on my way home with a new key for about £7.50 not bad.
