Ideas needed...backrest
  • dntemp_ca
    • 167
    • Kenora, Ontario
    Need input.
    Have any XSives out there built a driver backrest for the XS11?
    I'd like to add one and am looking for ideas.
    Dennis
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    The rack/backrest that came with my E was adjustable to accomodate the driver. It never came forward far enough for me to lean against. On trips I lean bak on the sleeping bag (or passenger)
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      Hey there Dennis,
      I, too, built one for mine, but it was only for the passenger. My 81 has the thicker flatter shaped grab rail, and I drilled holes thru it to mount brackets and square tubing that I mounted a backrest pad onto. I got the vinyl fabric from Walmart, Foam from mattress or Arts/crafts store, used piece of wood for support, hot glued the pad/cover together and screwed it to the metal support! And now that I have a welding machine, I could probably do something even better, even with some round tubing to allow it to slide to adjust to either my back or passenger!
      Good Luck.
      • dntemp_ca
        • 167
        • Kenora, Ontario
        I have a travelcade style seat and a backrest that slides into the rear carrier. Like Pat says. it doesn't slide out far enough for me to use it when I'm solo. I think I might try to rig up an extension out of a couple different sizes of tubing so that it will move farther forward.
        Dennis
