Hey there you Auto techies,
I've got a Chevy, 94 Corsica with factory air, been great for 10 years, recently tried to use it, and only room temp air. Also didn't notice the engine drag when turned on like it used to. Checked under the hood, with engine running, turned the AC switch on, fan starts blowing inside the car, but I can clearly see that the Electric Compressor Clutch is NOT engaging!!! It's just free spinning like it does when it's turned off.
Since the inner fan is blowing, can I rule out a FUSE? Can I check this clutch with jumper wires to ensure that it's the clutch mechanism and not just a short in the wiring going to it? Thanks in advance for any pointers!
T.C. getting hotter under the collar everyday!!
PS, not much action in the FORUM, must be great weather across the country and everybody is out riding!!!
After I disconnected the charging lines, and put the blue plastic cap on, I then turned the car off. I then noticed that I was still hearing the sound of gas escaping!
I opened the hood, and it was emminating from the low side valve. I removed the blue cap, and it was leaking, apparently a slightly damaged ?Schraeder? type valve, so I put the bluc cap back on which had a rubber oring seal is the top, and really torqued it in place, and the leaking sound stopped!
I guess I'll probably end up taking it to an AC shop if it doesn't hold so it can be vacuum filled as well as fixed!?
so i'll quit rambling for now - hopefully this helps you out - sorry to rant for so long
