Engine compression gauge purchase questions
  • 2manybikes
    • 194
    • Meadows of Dan Va.
    I would like some suggestions for a good quality compression gauge for my bikes. I have no interest in using it on anything else. Yes I know Harbor Freight and Sears sell them, and perhaps both of them are fine, but I'm curious as to what the board members use. I do know I am only interested in the screw in type.
    buy one at Sears, not harbor freight. It should have adaptors for either plug thread size.
      I checked out the HF and Sears and Autozone ones online. Sears sells the Innova brand, same as Autozone. They/Sears also sells the inexpensive Actron type which looks very similar to the one I got 30 years ago. It has dual sized threads and O-rings on the same tip, so you don't have to swap fittings for it to fit 14 and 18mm threads. My 30+ y/o unit had the release valve on the unit next to the gauge as well. The only thing different is that mine has the display/gauge perpendicular to the hose like the top of a letter "T", whereas these gauges have the display in the same position/direction parallel to the hose. I don't know If the gauge will SWIVEL on the end of the hose, so it could be difficult to view the gauge after screwing it in.
        • 2158
        HF works for ne
        I'm quite satisfied with the Harbor Freight model.
        Seems accurate,... has O-ring equipped fittings to accommodate both plug sizes, and cost was only $10.
        • 2manybikes
          • 194
          Compression gauge
          Thanks to motoman, TC and Radioguylogs for promptly responding to my question. Mike, I will have to admit, your endorsement of the HF model will have me taking a second look at it. So here I am, giving my other friends a kick in the rear end. Come on guys,I know there are more than 3 people who use these things and have an opinion! Hello out there in XS land.
          • Barbarosa
            • Jun 2009
            • 135
            • Fayetteville, AR
            Been using my HF rig for over 10 yrs and it has worked fine. Will do 3 plug sizes and the case stores the hoses and gage nice and compact. IMO it is accurate enough to diagnose a major difference between the cylinders or to do a wet/dry test dependably. It works as well (identical readings) as a Stewart Warner that a friend has and was 1/3 the price so I am pleased with how it performs.
            1980 xs1100SG "Silent Killer"
            1948 HD FL "Thin Mint"
            1978 FLH 80 "Grumpy"
            1960 HD FLH Duo "Blue" (w/family in Sacramento)
            1986 Honda CMX 450 (51hp rat sleeper) SOLD
            • 2manybikes
              • 194
              Compression gauge
              Barbarosa, Thanks for your input as well. Looks like I will have to mention motor oil or tires to spark the natives into action!
                • 4012
                I have a Snap-On compression tester, and two Harbor Freight one's. I have the Snap-On tester in a case, and the HF one's in a tool cheat drawer. The HF one's always get used, and always work.
                • 2manybikes
                  • 194
                  Compression gauge
                  Ian, thanks for your input. HF it is! Glad I asked before spending more money than I needed to. Thanks again, for everyone's input.
