The importance of battery maintenance
    Originally posted by GLoweVA
    So, it's been probably a year since I've checked my battery, so i decided since i was putting new horns on and had the seat off, I'd pull the battery out and make sure the water levels were okay.
    Here's what i saw. ��
    So, the moral of the story is: Don't forget to check your battery at least twice a year.
    Battery electrolyte/distilled water normally does NOT evaporate. Ideal charge rate for automotive world 12v systems IS 13.8-14.2v. Motorcycle charging systems, for whatever reasoning is a bit higher than the ideal maximum charging voltage, which can and does cause minor evaporation of water/electrolyte.
    Your battery being THAT low on distilled water/electrolyte leads a suspicion to the large plug-in behind the fuse panel. Regulators have no way of knowing there's a voltage drop due to poor connections from alternator to regulator to battery. Result is a higher charge rate than necessary in relationship to voltage being used by system from battery.....resulting in an overcharge rate, which results in electrolyte evaporation.
    BTW, was trained specificly in all aspects of 12v charging systems some 40yrs. ago........but slept since then.
    FWIW, I normally get 7-12yrs. of use from an Interstate battery WITHOUT a re-charge. That amount of time use IS considering rest of systems electrical charging circuit IS operating correctly!
      In reference to my previous post(#16), after filling battery EVENLY to full line with distilled water ONLY, with battery removed I'd put it on a NO larger than 1amp charger for 4-6hr.....check voltage with volt meter.....install and ride.
        • 6765
        I went to AGM type batteries years ago...and havent looked back...there are some things that can stand improvement and the this is one of them...YMMV
        2005 Honda SilverWing 600
        2018 Honda PC-Xpress 150
          Originally posted by motoman
          ......Interstate.
          Incorrect. Interstate batteries are manufactured by Johnson Controls.
          • ESJr1642
            • Jan 2012
            • 103
            • Groveland, FL
            Battery Manufacures
            East Penn is the third one I believe.
            1979 XS110F, Stock
            1980 XS1100G, Mostly Stock, gifted to my son.
            2000 YZ 250, Sold
            2002 YZ125, Sold
            2009 Royal Star Venture
            '94 Pontiac Trans Am, 25th Anniversary, For Sale
            Ernie
            • ViperRon
              • Feb 2011
              • 1062
              • Woodstock, VA
              Get an AGM battery I believe in them many boast Lithium is the new direction however I believe lithium is a little too high tech for our charging system and lithium is picky about vibration heat and needs a very consistent charge or it explodes. I have also had regular acid batteries have charging issues and explode so I am a firm believer AGM is the way to go for now.
              I also believe you have the right to buy what ever you want and can get but we will pick on you if we find out you have a problem
              Rodan
              1980 G Silverbird
              1198 Overbore kit
              Grizzly 660 ACCT
              Barnett Clutch Springs
              R1 Clutch Fiber Plates
              122.5 Main Jets
              ACCT Mod
              Mac 4-2 Flare Tips
              Antivibe Bar ends
              Rear trunk add-on
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                That's who makes that Battery Mart Big Crank Battery.
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                • MPittma100
                  • Aug 2011
                  • 2359
                  Agm
                  I've used the AGM batteries for a long time in everything I have. After many years of experiencing acid corrosion damages and battery explosions, I officially refuse to buy the lead acid type again.
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                    • 6765
                    Exactly...back when i had my Maxim...the battery electrolytes spilled somehow...it ran down the frame rail and left a huge stain on the chrome finish of my exhaust pipe..plus i really suck at battery maintenance...
                    • DeanR
                      • Jan 2005
                      • 1499
                      • Finger Lakes NY
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
