Your PM Inbox is full.
IanDMacDonald
IanDMacDonald
Theodore RooseveltTags: None -
Recrified. Thank you.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights. -
Just as a reminder folks,
When you send PM's, unless you UNCHECK the checkboxes on the bottom of the PM creation window before you send your PM, you will accumulate copies of your SENT PM's in a separate box. And they add up towards your total # of PM's you can have, both received and sent! SO...remember to view your SENT folder, and trim the fat there as well!
T.C.T. C. Gresham
Nate, it was maybe just that Ian didn't want to talk to you.. Just a thought?Try your hardest to be the kind of person your dog thinks you are.
Theodore RooseveltComment
It's that time again IanNathan
Wow TR that puts Nate in a bad spot he believes his wife and thinks he is a dick or doesn't and becomes dickless and it all started because Ian did not want to talk to him or clean things up. The things we learn here
Now to keep this from happening Ian just keep a little cloth with bleach in your pocket and you can clean it. That would be the politically correct way to stop this. Now you still might have a wickyleak but no real evidence of what you did.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
Fixed. Thank you.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Well I think I already answered my own question so it's all good.Nathan
