I have a '79 XS1100SF. I followed the instructions on the "new wires in old coil" post and rewired the pack for the 1&4 cylinders. It all looks good, but when I test the ohms on the secondary resistance I still get 1. (Primary resistance - I'm getting 1.7K; secondary should be around 15K +or- 10%). I'm stuck. These coils are almost non-existent anymore. Any ideas? Thanks
Coil pack help
Internally, having epoxy, they are likely getting fractures in the epoxy from heating/cooling cycles over the years causing resistance loss. Either new Accell or other aftermarket coils are needed. In my case several yrs. back, my Venturer 3ohm coils were failing to a point of 1.4ohms. I replaced them with a set of Honda VFR coils. This also gave me my choice of spark plug wires as they are attached separately. I opted for 5ft. of 7mm high temp steel braided wire core plug wire cut to 4 specific lengths. Also, the VFR coils ohms are not marked as such externally, so having my meter with me to check different ones was necessary. I might add that Honda coils, even being older ones are NOT notorious for any type of failure...JATI have a '79 XS1100SF. I followed the instructions on the "new wires in old coil" post and rewired the pack for the 1&4 cylinders. It all looks good, but when I test the ohms on the secondary resistance I still get 1. (Primary resistance - I'm getting 1.7K; secondary should be around 15K +or- 10%). I'm stuck. These coils are almost non-existent anymore. Any ideas? Thanks
. They also bolt to frame in identical position and use identical bolt mount positions
. In order to keep the same harness plug-in assembly, I unsoldered the plug-ins from original coils and resoldered them to the VFR coils and used a piece of small shrink tubing covering the connections at the coils. Secondary ignition has worked perfectly since
. Some Honda VFR coils are also 1.5ohm, which is what is needed in your bikes case if it's the one you have listed(78-80 uses 1.5ohm coils)
Last edited by motoman; 04-24-2016, 02:08 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
You don't have to use the 1.5 ohms coils! Just bypass the ballast resistor so it sends 12V to the coils all the time, and the TCI will still see a total of 3 ohms vs. the 1.5 ohm ballast resistor and the 1.5 ohm coil.
T.C.T. C. Gresham
