I got a 1978E with 80's model carbs. I am rebuilding carbs new needles and seats and a good cleaning. I got on here on old posts and found all the infro. I needed to do all my work. If you keep looking you will find it. Thanks to XS 1100 .com. !!!!!
Thanks To XS 1100.
Tags: None
The search function on XS11.com tends to be one of its weaker points. Sometimes I have better luck doing my searches in Google, and just including XS11 in the search terms - particularly for older threads. Congrats on finding what you needed and getting the job done!I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake lines -
Hey Doc,
Just hope you've seen some of the newer carb threads....and that you ordered GENUINE MIKUNI for your float needles/seats!? We found that the Generic ones are a different size/length, and can lead to flooding and leakage even when set to the proper height!!
T.C.T. C. Gresham
