Good source for green coils in Canada?
  • kevxs
    • Apr 2009
    • 353
    • toronto
    I'm going to put the Green Dyna 3 Ohm Dual Output Coils on my bike this year. I can buy them from Dennis Kirk for $154 + $40 shipping (USD) does anyone know a cheaper source? I need shipping to Toronto.
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • MPittma100
    • Aug 2011
    • 2359
    Dyna Coils
    Better price here:
    http://www.amazon.com/DYNA-IGNITION-...=dyna+ignition
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • kevxs
      • Apr 2009
      • 353
      • toronto
      just checked, they won't ship to me
      hope you guys appreciate amazon.com, we have to live with amazon.ca
      I can get it delivered to port huron as I have family in the Sarnia area but I'm hoping to avoid the hassle.
      Green Dyna Coils
      1973 CB100
      kevXS
      • kevxs
        • Apr 2009
        • 353
        • toronto
        on closer inspection those say 'single output' coils, but I need dual output right? the picture is wrong i think.
        i found these ones and they will ship to me for $15 so that looks reasonable to me.
        http://www.amazon.com/Dynatek-OHM-Du...l+Output+Coils
        They aren't green in the picture so hopefully someone can chime in and confirm those are the coils i should get before I order them.
        Green Dyna Coils
        1973 CB100
        kevXS
        • mikubuilder
          • Jul 2011
          • 548
          • Westland, Mich.
          That's the ones...I just got them from Amazon also, but a lot cheaper ($115 + free shipping), with new cables(another $18)...but yeah DC1-1 is what you need...just remember to bypass your resistor.
          Nick
          1982 Virago 750 (it's alive!)
          • Bergman16
            • Jun 2014
            • 286
            • New York, N.Y.
            http://www.ebay.com/itm/360658832628...%3AMEBIDX%3AIT
            I think they ship for 9.95 to canada. $118--the company is also on amazon...
            Steve R
            '80 SG
            Former bikes:
            1978 XS400E Red
            1981 XS850 Special (Stingo)
            • kevxs
              • Apr 2009
              • 353
              • toronto
              I have my new green coils now, thought I could re use my old wires from the old (dead) black mikesXS coils but they seem to be a different style. Can anyone tell me excatly what wires I need to buy? Would canadian tire have them? I went to Partsource and the lady at the counter said they don't have the wires I need cause its for a bike. I figured bike and auto wires would be pretty similar but I don't know.
              On another note, today was my first day riding into work . Bike is running great, can't wait to get the new coils on and see if my MPG improves.
              Green Dyna Coils
              1973 CB100
              kevXS
                • 4012
                Grab some 7mm solid copper wires made by Dyna. You could probs find them on eBay for less than $25
                And, regarding the fuel mileage, you probably will not see a gain.
                  Hey Kev,
                  You CAN use your old MikesXS wires, it's just that you need the different type of ends that fit into the Dyna recessed wells..vs. the male screw that's in the old Mikes Coils. I bought some other 4 cylinder car wire set just to get the plug wire ends. Took them off of the car set, and put them onto the MikesXS wires, then just pushed them right into the Dynas.
                  Here's an image from another forum I found that sorta shows the type of ends you need for the wires. You may be able to find something like that at your local Canadian Tire or similar store??
                  Here are some brass wire ends for 9mm wire on eBay just for an example, you may be able to find them also at C.T.!? You'll want to strip back ~1/2" of insulation to be able to fold over the solid wire core around the end of the wire and thru the end of the wire end clips for better contact.
                  http://www.ebay.com/itm/5-Brass-Term...r#ht_22wt_1153
                  You will still need to get some coil side boots for over the wire and onto the coil housing. OR you could just slather a bunch of RTV around the wire and coil after plugging it into the coil.
                  Ditto, not necessarily better mileage, but much easier starting and better, smoother, stronger running!
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    thanks for this, very helpful as always.
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                    • kevxs
                      • Apr 2009
                      • 353
                      • toronto
                      getting closer to installing these, I have all my parts now. Should I re gap my plugs after installing the new coils? I thought I read that on here somewhere . . .
                      Green Dyna Coils
                      1973 CB100
                      kevXS
                        • 4012
                        You can "check" the gap on the plugs, but if you're talking about going to a different gap other than spec, I think you're wasting your time. I know many have said that the gap was off upon checking new plugs, but I never check. I just always assume they're correct.
                          Hi Ian,
                          While new plugs come with some gap it is always a good idea to check them before installing to be sure they are correct o XS specification.
                          • Gmac
                            • Aug 2014
                            • 256
                            • Huntsville, AL.
                            I have a tool
                            I inherited from my grandfather to check plug gap. It uses a round 'U' wire in graduated sizes, easy, fast and I always check the gap on new plugs.
                            It takes seconds and if they need tweaking its just a few more seconds and then they go in. I guess I'm just a perfectionist, now if I could stop procrastinating...
                            79 SF & 80 LG MNS
                            73 & 74 RD 350's
                            73 Honda CL 450
                            Graveyard - '81 XS850 Special
                            • kevxs
                              • Apr 2009
                              • 353
                              • toronto
                              new coils are in
                              Finally got the new coils installed yesterday, went for a short ride and sure feels like I've got a lot more power, exhaust smells cleaner too. can't wait to put a few tanks of gas though it and see if my mileage improves.
                              Green Dyna Coils
                              1973 CB100
                              kevXS
