99 Silverado 5.3L aluminum heads. Exhaust manifolds leak due to a couple exhaust manifold bolts have the heads broke off. Of course it's the farthest rearward bolts on both sides. I can't get at it good enough to drill them out so I am pulling both heads and do it right. I will be replacing the bolts with Dorman exhaust manifold replacement bolts. I got out the rest of the bolts, they don't appear to have anything like anti-seize on them. Should I put anti-seize on the new bolts?
The torque specs I find for torqueing the heads say torque to 90 deg. Do you have to have the special tool or can you get away with torqueing them with just a torque wrench? Torque to how many lbs?
How do you remove the wire on the knock sensor that is under the intake manifold? Do you need a special tool? Any and all help is greatly appreciated.
