Chevy 350 valve seals
  • red bandit
    • 950
    • central michigan
    I have an RV it's on a 85 Chevy van 1 ton chasis with a 350 engine. I'm replacing the valve seals, it has the o-ring type. I don't see how they could do anything as far as preventing any oil from going down inside the valve guide since they fit in a groove on the valve stem and move up & down with the valve. Am I missing something? My question is could I use the cup type valve seal that fit on the boss of the head like on the xs11 or would the groove in the valve stem when fully opened go down inside the seal & start to cut the inside of that type of seal?
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Those are the original type seals. They do work fine, but they do make the cup style stem seals in a positive seal type. Check with a good parts man, and he can hook you up.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
      • 9980
      Those O-rings work perfecty.
      • red bandit
        • 950
        • central michigan
        Thanks for the knowledge.
        79 SF parts bike.
        • MPittma100
          • Aug 2011
          • 2359
          SBC Valve Seals
          The orings do work. They are installed after you have the spring and retainer on the valve, not before. Otherwise you will cut or move the oring out of its slot.
          You can use the umbrella type as mentioned, but you must machine the outside of the valve guide to accept that seal. It takes a special tool to do that.
          MP
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
            • 9980
            MP
            How do you figure getting that seal on the valve stem after the spring and retainer on Mike?
            All of them I've installed didn't fit in a groove, they just fit around the stem.
            • red bandit
              • 950
              • central michigan
              These valves have a groove.
              79 SF parts bike.
                • 9980
                Yeah, your right. It's been a while since I rebuilt a head on an older Chevy.
                They don't look like they'll work but they do. I had the same thought when I first encountered them 35 or 40 years ago.
                • MPittma100
                  • Aug 2011
                  • 2359
                  You just push the spring/retainer down further until the groove is visible and slip the oring into the groove. Install the keepers and you are ready for the next one. Viola!
                  K&N Air Filter
                  ACCT
                  EBC Front Rotors
                  Mike
                    • 9980
                    The seal is below the keepers though.
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Seals
                      Yes, there are two grooves in the valve stem - lower one is for seal, upper one is for keepers/locks.
                      K&N Air Filter
                      ACCT
                      EBC Front Rotors
                      Mike
                        • 9980
                        It's not even necessary to compress the spring/retainer past that point to install the keepers so why do it and then have the retainer go up over the seal anyway?
