Generator unused for 8 years - want to use it.
  • KA1J
    • 664
    • Groton, CT
    Hi,
    I just picked up a Honda EU2000i that has been in the box for the last 8 years, never had gas in it. Before I start it I thought I should maybe squirt some oil in the cylinder & let it sit that way for a bit to let the oil drain past the rings. Maybe that's not necessary?
    Any suggestions before I pull the cord?
    Thanks!
  • Murrayf
    • Jul 2014
    • 41
    • Lexington , N.C.
    its a single cylinder
    a little top end oil wont hurt before starting or some atf
    i would make sure it has fresh oil in it
    then start it up and put it under a moderate load for a while to let it seat in
    79 SF
