Replacing air box with pods-do I need to adjust my carbs?
  • mzimmer28
    • Mar 2009
    • 2
    • Vineland NJ
    I took out my air box on my XJ and am replacing it with 4 individual pods. Can anyone offer me any advice on carb adjustments that I need to make?
    1982 XJ1100 Maxim
    2013 XT250
    1995 Harley Davidson Sportster 1200
    • 8929
    You may have to increase main jet size up a couple, I would try it first the way it is and see how she runs, check the spark plug color and go from there.
      If your running stock exhaust, it is likely stock jetting will work fine for you. If your running an aftermarket exhaust, it becomes less likely, but it may still work fine for you.
      I would follow Phil's advice, he is a very smart guy.
        • 8929
        MZ, stock jet sizes for an XJ should be 47.5 pilot jet and 112.5 mains. Careful about the type of pods you run, some cheaper ones block the air jets in the back of the carb.
        • mzimmer28
          • Mar 2009
          • 2
          • Vineland NJ
          I am leaving the stock exhaust, so I'll just give it a try! Thanks guys!
          1982 XJ1100 Maxim
          2013 XT250
