Replica badges
  • James England
    • 3039
    • North of England
    Replica badges
    Here's the man for replica badges..made of metal. I bought a rear seat cowl badge for my XS11.;, metal with real gold plating. Much better quality than OEM actually.
    Badge Replicas Australia specialises in high quality motorcycle tank and side-cover badge replicas for , Suzuki, Yamaha, Kawasaki, Laverda, Benelli, Moto Guzzi, Ducati, Other Japanese and some European and American brands. We also supply classic Suzuki parts.
    • 8074
    James,
    A friend of mine bought badges for his XS-2. He had to send them back as there was no way to make them fit.
    I have heard others say they are flat and have to be bent to conform to the side cover or tank. I also understand they are shrunk 10% from the originals and the mount holes do not line up. What was your take on it?
    I have new OEM badges to go on my tank. I was considering leaving the side covers badgeless.
      • 4012
      BBookmarked that site. Thanks James.
        • 8074
        The Australian badges are distributed by some vendors in the US.
        Diablo Cycle
        • James England
          • 3039
          • North of England
          James,
          the European XS only has one badge..on the rear seat cowling. The others are under the lacquer decals. So I only bought the seat cowl badge. It was exactly the same size as OEM. However, it was flat. I bent it very slightly, without any problems to the plating and the two mounting prongs lined up fine. Having paid about $40 for it though, I used double sided sticky tape and also small circular grip washers on the little prongs.
          Bending might be an issue if the side panels are very curved though. The badges are die-cast metal, then electroplated. I suppose a drastic bend might crack the plating though! Maybe ask them about it?
          • Far Canal
            • Jul 2013
            • 44
            • Tasmania, Austrailia
            I would not recommend them at all. Bought a couple for my Special, they were flat and did not match the curve of the sidecover. Also the lugs did not fit the holes in the sidecover properly. I tried to gently bend one of the badges to suit the curve of the sidecover and it snapped in two! I was getting pretty angry by this stage and contacted the supplier who in fairness sent me another one. Ended up buying an original one off ebay. The metal ones are still in the shed wallowing in disgrace.
            It's true these badges look good, they are nicely finished. On the other hand they are very heavy for the size of them. Much, much heavier than the actual sidecovers onto which they go.
            79 SF
            Honda KO 750
            Honda K2 750 Bobber in progress
            Moto Guzzi 1000cc mongrel custom
            HD FXST 2008
            Bonneville SE 2010 (wifeys)
            • MPittma100
              • Aug 2011
              • 2359
              James,
              Hi Marty,
              You are correct in what you have heard about the badges. The tank emblem mounting holes do not line up with existing tank holes. They can be made to work, but you have to drill and tap one new hole in the mounting bracket on the tank on both sides. Side cover emblems have to be bent ever so slightly to fit. Must be careful as they are easy to break. The emblems are metal and much heavier than stock. They are also quite expensive and take a while to obtain them sometimes. Not a whole lot of options other than finding them on Ebay on occasion.
              The link that I have used in the past is as follows and I am pretty sure it is the same people as James is referring to:
              Vintage motorcycle parts and high quality self-adhesive vinyl decals for 1959-90 european bikes. Helping people restore their old motorcycles.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • DAVINCI
                • Jan 2011
                • 1048
                • Cedar Mountain, NC
                James,
                TRUE, Marty. I installed them on mine. They are very nice, but slightly smaller and I needed to drill / tap one end of the mounting flange on the tank. It was a nitroglycerin moment to say the least.
                • James England
                  • 3039
                  • North of England
                  Well, that bottoms that one out! All useful info. Looks like I'll be buying only seat cowl badges from them!
                  Glad everyone posted. Very handy to know for the future.....
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Emblems
                    James, their badges obviously are not an exact fit, but are usable - especially considering that there are not a whole lot of choices. Seems like they could adjust a few things in production/manufacturing and have a real winner. If it was my company, I would see to it that they were corrected to fit.
                    Mike
                    K&N Air Filter
                    ACCT
                    EBC Front Rotors
                    Mike
                    • Mathh
                      • Nov 2006
                      • 698
                      • Beek, Netherlands
                      Not completely true James The 3x0 and 3x1 both have the fat logo's and he is also offering these.
                      i think the logos can be heated a bit and then will be easier to curve them around the hump or side cover. Maybe dip them in warm water for a while and give it a try.
                      MV Agusta Brutale 910R '06.
                      Yamaha MT-09 Tracer '15 grey.
                        • 8074
                        For that kind of money, I want badges that fit.
                        New OEM tank badges are available for the SG and SH. They will fit the SF. The cost is far less than the reproductions.
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          I got the side cover replicas from the Canadian Diablo cycle ended up they came from an Australian company took more than 2 months to come in. They were flat but I used soft cloth and shims to slowly bend them in a vice to have the cupping to fit the side covers. Took about 2 hours being slow and carfull to get them right. They fit the holes but I still put some 2 sided tape on the edges so they would not slide around and for sure I did not want to loose one on the road. Actually originally mine had a thin rubber backing on the side cover badges. The replicas are much heavier than the plastic. If there was a difference in size I could not see it. For the gas tank I got 2 original Yamaha part number plastic badges from a Yamaha shop on EBAY selling old stock. The tank badges where not cupped perfect but when the screws tightened down they fit perfect. I do have the standard model which is different from the special and that is where I had been told there was a difference as far as holes lining up.
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          Barnett Clutch Springs
                          R1 Clutch Fiber Plates
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
                            These are chrome instead of gold but for $4.04 each who really cares? And, the screw holes match perfectly.
                            They are actually for a golf cart and are flat but with a little heat (on the back ) they can be formed and fit just fine.
                            http://www.boats.net/parts/detail/ya...161-01-00.html
                            This is what they look like on the tank......
                            • James England
                              • 3039
                              • North of England
                              Emailed Oz
                              I emailed the badge company in Australia and directed him to the forum thread re these badges... Here is the reply I received...
                              Hi and thanks for the link to the forum comments re the Badge Replica badges.
                              There are a lot of misconceptions out there re the badges we sell and the comments reflect this.
                              Yes the badges are heavier as casting them is the most cost effective way to do them and keep the price reasonable.
                              Most of our badges have been altered to suit the mounting holes if they are fitted with pins on the rear of the badge.
                              Badges with holes are very difficult to alter and as such are a bit more difficult to fit.
                              When cast (mold is made from a NOS original) the badges are no more than 2-3% smaller not 10% as mentioned.
                              I have owned this business for 3 years and in that time I must say I have had 99% of satisfied customers, the unhappy customers are generally dealt with to a satisfactory result and on the rare (very rare) occasion I have refunded money for badges returned, (twice this last year)
                              Considering the several thousand badges I sell each year I consider this a good result.
                              I am always trying to improve badges where it is possible but sometimes the quantity sold does not warrant the expense.
                              We are trying to provide a service and a product that is no longer available and feel we are doing a good job.
                              If only people contacted me rather than venting on forums I might be able to help them.
                              Thanks again for the link as it is always good to hear what people think, good or bad.
                              Regards
                              Cal Merlo
                              Badge Replicas
                              BadgeReplicas Australia specialises in high quality motorcycle tank and side-cover badge replicas for , Suzuki, Yamaha, Kawasaki, Laverda, Benelli, Moto Guzzi, Ducati, Other Japanese and some European and American brands. We also supply classic Suzuki parts.
                              cal@badgereplicas.com.au
