Anyone Here HAM?
    Anyone Here HAM?
    Any HAM radio people here? I am looking to get into it and am looking for some advice on where to start.
    Breaker breaker 1 - 9. C'mon back, you got porky pig here.....
      Hi Greg,
      that's CB talk. An amateur radio message should start with CQ - - -
      • hamjam
        • 1003
        • Toronto ontario Canada
        - .-. -.-- / -.-. .... . -.-. -.- .. -. --. / - --- / ... . . / .. ..-. / - .... . .-. . / .- .-. . / .- -. -.-- / -.-. .-.. ..- -... ... / .-.. --- -.-. .- .-.. .-.. -.-- :d
        Seamus Ó hUrmholtaigh
        Niimi Moozhwaagan
        NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
        Any connection between your reality and mine is purely coincidental.
        Member of "FOXS-11" (Former Owner of XS-11)
        and SOXS
        2008 Nomad "Deja Buick'
          You don't need to know Morse code anymore.....
          There are some but I just like to know what I am getting into before I start.
            • 7830
            Nate,
            I just upgraded from a technician to a general license. I work for a company that builds HF radio's, so I can now talk on one!
            The Technician test is a lot about Ohm's Law, rules, and Frequencies. IF you buy the book from the ARRL, it has a CD in it with all the questions in the pool the FCC uses. It is a very good way to learn and then take the test at a local site. You can also find the questions online if you do a google search on HAM TECHNICIAN TESTS. If you find that you seem to pick it up easily, then study the General questions as well! It took me almost 20 years to upgrade, and I probably could have done both at the same time. It cost $15 most of the time to take the test, and that is if you take one or all three. There is NO MORSE CODE needed anymore, though a lot of HAMS still use it.
            It's a fun hobby, and a way to help out in times of local need. Most of the time when nothing else will work, a HAM operator will be able to get a message out to where it needs to be.
              Yeah, I thought about doing both tech and general together. I was looking at a sample test the other day and got about 2/3s of the tech questions right and didn't have any clue as to what the tests where about.
              I am just a bit confused by all the equipment! I got a little el cheapo baofeng handheld just for now to listen and get a little used to it. Tried to transmit once (even though I am not supposed to ) but I can't even figure out how to do that! Apparently just pressing the side transmit button is not enough in ham......
                • 7830
                That "RADIO" is owned by a few hams who cannot program it without a computer! Use it to listen to repeater traffic, but you will need to look for a "real" radio to really do anything beyond very short distance, about 10 miles.
                One thing I've found is you need a general to go above 10 meters, and that is what you need to talk across the country or around the world. Used Icom, Yeasu, or Kenwood radios can be had in working order for about $150 to $250 for HF. 2 meter 70cm radios are less than that new. I work for Elecraft, and they start at about $800 for a portable, the KX3 and $2500 for a 100W HF, the K3, that is one of the best in the world. No, I do not have one yet, as I need to save a LOT more pennies to buy one. I AM taking the "loaner" KX3 with me to Kona tomorrow, and will try to talk with a co-worker Wednesday afternoon my time.
                Passing is only 26 out of 35 for both tests, so you should do well! Give the general a try, as the worst you do is fail. I did that on the "extra" test when I took the general, and got a 22 out of 50! I thought that wasn't bad, as I had not even seen a question before trying, and it is by far the hardest of the three.
                  I got the programing cable with the radio, all the reviews said it was near imposible to program the on screen menu, but that Is really making a lot of sense either.
                    Ray, I did figure out how to transmit on my el cheapo handheld. Bit of a hassle but it works. I also ordered Yaesu 2m mobile.
                    Now I just need to get licensed.
