slide diaphragms
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    slide diaphragms
    Has anyone tried these people? It sounds good, $20 a piece. I have been working with my xs750 and my diaphrams have holes in them. Will holes in the diaphragms make the idle hang? Does anyone have any diaphrams? The xs750 and xs1100 have the same ones. Thanks.
    77 XS750 2D completely stock
  • kflyboy
    • Apr 2012
    • 81
    • Lakewood, Colorado
    slide diaphrams
    I did not see in your post who these people are. I bought mine for my xs11 at JBM industries. They work great and holes will cause wierd idle issues.
    • jjz28
      • Apr 2012
      • 1023
      • Beckley, W. Va.
      Duh! man, I am sorry, here is the link, I forgot it and its the same place you used. http://jbmindustries.com/Yamaha650.html
        • 8074
        The XS650 folks say good things about them. There are a couple of other options.
        • tarzan
          • 1700
          • Chandler,Az.
          Those diaphragms work great and are easy to install. I have them in my carbs right now.
          80 SG XS1100
          14 Victory Cross Country
          • rdmcguy
            • Jul 2013
            • 515
            • Denver, Colo.
            Slide diaphragms
            I bought a set and they work great.
            They have a tutorial on their site It's a pretty simple procedure,
            Make sure the little hole inside your slide faces the intake side.
            It's easier to seat the diaphragm in the carb body groove if you lift the slide a bit
            Good luck.
            Joe
            • jjz28
              • Apr 2012
              • 1023
              • Beckley, W. Va.
              thanks guys. I am going to order them. 2 of the 3 on the 750 had little holes in them but I am going to go ahead and get all 3. Could these cause a hanging idle? that's the problem I was having. I also have all 3 intake valves too tight and one exhaust too tight.
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                Sounds like they need to be synced still if you have a hanging idle. Otherwise I would check the cable isn't hanging up. Holes in the diaphragms would make the slide slow to lift and make it sluggish.
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
                • jjz28
                  • Apr 2012
                  • 1023
                  • Beckley, W. Va.
                  I never synched them, just a bench synch. I have never synched the xs1100 either but it must be a lot closer cause it runs great. I just thought it was weird that I could turn all mixture screw and it didn't make a difference.
                  • jjz28
                    • Apr 2012
                    • 1023
                    • Beckley, W. Va.
                    Has anyone tried the plastidip that is in the tech tips for fixing the pinholes in the diaphragms? I am going to try it. That is all that is keeping me from fixing the xs750 at this time and if it don't work, I will just get new ones. Just wondering if anyone has tried the plastidip though. THanks.
                      • 8074
                      I fixed a couple of little holes with rubber cement or something similar. Emphasis on little.
                      I think way too much weight get put on carb sync. Yes, the sync will get the idle near perfect, but you can have a great running bike and never put the sticks on it.
                      I don't believe holes in the diaphragm will have much effect on idle. I think something else is the issue. You may have missed something along the way.
                      Also, check out eBay seller MOTOALLPARTS. He's got diaphragms and 100% positive feedback. He also has a nice tutorial posted in his listings.
                      • jjz28
                        • Apr 2012
                        • 1023
                        • Beckley, W. Va.
                        I used the plastidip and the bike runs pretty good right now. I think my whole problem might be one of those carb boot clamps. I cant get the middle one tight because its stripped. After I get a new clamp, I think it will be good to go.
                          Won't work for very long as the plasti-dip doesn't withstand the fuel fumes up in that area. When removing the slides/diaphrams later on, you will find pieces of plasti-dip everywhere in tha chamber......BTDT.
                          • jjz28
                            • Apr 2012
                            • 1023
                            • Beckley, W. Va.
                            I figure that will happen. I will get new rubbers before spring.
                              • 4012
                              I believe the recommended fix for the diaphragms is gorilla glue.
