Understand your frustrations getting that scoot runnin' correctly, but we here have to make judgement calls not actually being there with the bike, and sometimes don't get the whole story when an issue arises. Several of us here have decades of experience with these and other bikes and ****-loads of experience in the automotive world whether it be everyday drivers or full on race motors. That doesn't even count the many that are electrical experts, professional painters etc.........think you get the picture. We here have never failed yet to help someone bring these bike to not only life, but running perfectly. Sometimes it takes a bit longer than if we were actually there, but never have seen a failure yet. Lack of info sometimes and the one asking questions sometimes tend to think they are asking dumb questions, so aviod giving details as to what they have or not have done to the point of asking. Not the case here, as the only dumb question was the one NOT asked. I, as many others have followed the issues with this scoot, so don't underestimate when we ask specific details that YOU may not think are relavent. No offense intended, but some of us here are decades and many steps ahead of you when we ask something that you may think is non-relavent. Ask away, and do try to follow what we suggest. We like to see all have success AND fun while doing it. The permanent grin WILL be worth the effort......ONE step and ONE change at a time till you and the scoot are happy.
Carb Tuning Success Story
Thanks Brant, I appreciate it. I will have to re-fuel and reset the odometer as somehow I forgot to, and I'm at over 200+ miles, and I still have a half tank of gas. no way is my tune that well. After I get a definitive mpg, I'll pull my carbs and verify float height and pilot/main jet size. I'll probs do that next week when I run her out of gas.1979 XS1100F
Originally posted by IanDMacDonald View PostThanks Brant, I appreciate it. I will have to re-fuel and reset the odometer as somehow I forgot to, and I'm at over 200+ miles, and I still have a half tank of gas. no way is my tune that well. After I get a definitive mpg, I'll pull my carbs and verify float height and pilot/main jet size. I'll probs do that next week when I run her out of gas.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by IanDMacDonald View PostYou guys underestimate me, lol. I put brand new plugs in after I got my final tune. I did not have my tan coat on the plugs yet after running it down to work and back the day before yesterday. So, after I got home, I turned the plugs a quarter turn (having a box fan on the engine, letting it idle), and the plugs instantly carboned. I cleaned the plugs with contact cleaner, turned the screws back to where they were, and that's where I am now. If I do a slow roll on the throttle, I have no hesitation, and the bike screams through all gears. But, if I WOT in-gear right now, I have a slight stumble. Runs great otherwise all the way up to redline.
I noticed nobody commented on my statement regarding the pilot jets, and my lack of needing to switch them.
As to your jetting, yes, I agree, if the bike ran fine before you changed the timing components with the jets you have, then it is most likely going to run just fine with those jets now. What were the mixture screw settings when it ran "like a raped ape in a cage"? Whatever those settings were, start from there. That should give you a very good starting point.
For those that might not have caught this, Moto's concern about mercury does not apply to the Mogan Carbtune tool alot of folks are using, those are not mercury filled tubes. You can hammer the throttle all you want while running.
The change in timing is going to effect how the bike runs, it may be the source of the change in performance your experiencing. No carb tuning will rectify the change from the timing adjustment.
Do clean your plugs or use new after each change in tuning. Looking at the color of the plugs after you let it idle for about 5-10 minutes will give you a good idea of how well the mixture screws are set. When I have a concern with low end performance, I ride the last 2-3 miles to my house (which is all 35 MPH zones) in 5th gear, keeping the RPMs close as I can to 2k or less. Then check plug color. This gives me the low end under load look at the plugs color.Life is what happens while your planning everything else!
Thanks for confirming my suspicions Doug. With regard to those "settings", they are now unknown to me, as I stupidly reset to 2 1/2 turns, automatically assuming a too rich/lean condition upon installing the de-tuned advance. I apologize if I offended anyone. I guess I get a little cocky sometimes, and I have no grounds for that (especially with "ruining" the bike, lol).
I feel I am at a good point in my tune right now, where only a quarter turn is the difference between a carboned plug and not. It's not right, and I'll work on to see what tje trick is.1979 XS1100F
Ian, Have you re-synced the carbs since the "last" adjustment? Just asking, as slightly out of sync WILL cause a stumble, BTDT. IF you are going to pull the carbs, you WILL need to re-sync once again. It's a pain, but it's also the ONLY way to get it running properly. And no, a color tune is NOT a sync, mercury/vacuum gauges, or the Morgan tune is what you need to sync carbs.Ray Matteis
Yup, carbs synced spot-on with Carb tune.1979 XS1100F
Originally posted by DGXSER View PostIan, no one is under or over estimating your abilities or knowledge, simply giving you information to hopefully resolve your problems.
Do clean your plugs or use new after each change in tuning. Looking at the color of the plugs after you let it idle for about 5-10 minutes will give you a good idea of how well the mixture screws are set. When I have a concern with low end performance, I ride the last 2-3 miles to my house (which is all 35 MPH zones) in 5th gear, keeping the RPMs close as I can to 2k or less. Then check plug color. This gives me the low end under load look at the plugs color.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Not So Successful
The SYMPTOMS: Requires light throttle upon start-up, STILL poor gas mileage, when the choke is all the way out, the idle does not rise to 3k like it did before, and now sometimes when the bike is warm, and I come upto a stoplight, the idle drops below 1k and the bike stalls out. I checked for vacuum leaks, etc. Don't know if it's related, but I let the bike idle too long at half-choke the other night, I pushed-in the choke and the bike died. I let it cool down, and it ran fine after.1979 XS1100F
Originally posted by IanDMacDonald View PostThe SYMPTOMS: Requires light throttle upon start-up, STILL poor gas mileage, when the choke is all the way out, the idle does not rise to 3k like it did before, and now sometimes when the bike is warm, and I come upto a stoplight, the idle drops below 1k and the bike stalls out. I checked for vacuum leaks, etc. Don't know if it's related, but I let the bike idle too long at half-choke the other night, I pushed-in the choke and the bike died. I let it cool down, and it ran fine after.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Yeah, I guess I'll pull them off tomorrow and check float level, alone with pilot/main numbers, etc. Thank you for the thought.1979 XS1100F
Originally posted by IanDMacDonald View PostYeah, I guess I'll pull them off tomorrow and check float level, alone with pilot/main numbers, etc. Thank you for the thought.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Checked everything over tonight. All genuine Mikuni jets. The Pilots were 42.5, however, the Mains were 140. I wonder if I dropped down to stock 137.5, some of those stumbles would be eliminated? Yet, I do have a less than stock airbox with Mac 4-2's. Float height was spot-on @ 25.7 mm.1979 XS1100F
Originally posted by IanDMacDonald View PostChecked everything over tonight. All genuine Mikuni jets. The Pilots were 42.5, however, the Mains were 140. I wonder if I dropped down to stock 137.5, some of those stumbles would be eliminated? Yet, I do have a less than stock airbox with Mac 4-2's. Float height was spot-on @ 25.7 mm.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Yuppers, I'll get to the shop in the morning before work. I was waiting on your reply Motoman. Thank you. Will try the 137.5's tomorrow after work.1979 XS1100F
