Just bought my second bike an '79 XS1100 Special
  • Rustitution
    • Aug 2013
    • 29
    • Philadelphia, Penn.
    on the left side i think it leaks at the top of the tube running down on the left.
    on the right side i think it leaks at the octy I need to lift the tank to get a better view.
    Rusty
    1996 Honda VFR 750
    1979 XS1100SF
      • 9980
      It's probably just old fuel line. You need to get some of THIS.
      Either order it (cheaper that way) or just go to your local parts house and ask for 1/4 Tygon fuel line. They usually keep it behind the counter. You'll need about 6' if you keep the octy. 3' if you remove it.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        octy
        Originally posted by Rustitution
        To BA80
        Thanks for the tip I bet its because its not even connected, there is something that looks broken on the boot I thought it a was plug that started to rot, but it maybe the vacuum hose you referred to.
        But while on the on, prime, or reserve, the bike runs fine, but if on prime or on it leaks, or at least I think that is how I have it, either way I'll fix the octy
        Should leak on all but off, check it out well as you may have a working octy and leaks from somewhere else ? Would be a shame to chase your tail as so many times I have only to find a cracked hose or loose fitting hose !
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • Rustitution
          • Aug 2013
          • 29
          I'm thinking that maybe the primary has more flow and thats why it leaks. but this is fairly inexpensive how many feet would i need to fuel lines?
          Rusty
          1996 Honda VFR 750
          1979 XS1100SF
            • 9980
            Read post #17
            • Rustitution
              • Aug 2013
              • 29
              *face palm*
              my bad.
              pros and cons for removing the octy?
              Rusty
              1996 Honda VFR 750
              1979 XS1100SF
                • 7941
                Pro: You get rid of some plumbing, and eliminate a vacuum valve that could fail and need to be rebuilt.
                Con: You lose a safety and convenience device.
                FWIW, I maintain mine, many eliminate it.
                  • 3918
                  Details on the exhaust and jetting for it? Sound clip?
                    • 9980
                    *face palm*
                    my bad.
                    I ran mine for several years and repaired it several times. I got tired of fixing it. Had it go out twice on long trips. Once I had to completely disconnect and bypass it because it was squirting fuel on the top of the engine and once I had to run on prime for about 1500 miles because the damn thing wouldn't open.
                    Pro= you don't have to screw with it on the road.
                    • dpotter58
                      • Aug 2004
                      • 1847
                      • Southern Maryland
                      I never had a problem with any of the 5 of the bikes I had them on. Some people have problems, most don't. Some people hear that they suck from a couple of folks and pull it. IMHO, if it works, leave it.
                      1980 LG
                      1981 LH
                      • Rustitution
                        • Aug 2013
                        • 29
                        To IanDMacDonald
                        I have no details on the exhaust other then when the PO got it it was missing the muffler so the got one and custom made the 4-1 joint.
                        sound clip is uploading to youtube now link is HERE
                        I was kinda hoping for something a little lower but I will keep it for now. My dad had a kerker competition exhaust on his.
                        Rusty
                        1996 Honda VFR 750
                        1979 XS1100SF
                          • 3918
                          Great, I'll take a listen. I love the Supertrapp mod some have done. In the future, I'd like to buy another bike, cafe it, and have a sport pipe on it and jet accordingly. I currently have Mac 4-2 turnouts on. I was thinking about maybe putting the Supertrapps on.
                          • jjz28
                            • Apr 2012
                            • 1023
                            • Beckley, W. Va.
                            The sound is good I think, much quieter than mine. Does that thing clear up when it warms up and you take it off half choke?
                            77 XS750 2D completely stock
                            • Rustitution
                              • Aug 2013
                              • 29
                              We finished the back rest but needed spacers to install it, so all i have are pictures of the finished back rest.
                              Rusty
                              1996 Honda VFR 750
                              1979 XS1100SF
                              • Rustitution
                                • Aug 2013
                                • 29
                                To jjz28
                                I think it clears up a little, it does need the carbs sync'd which I think will help clean it up
                                Rusty
                                1996 Honda VFR 750
                                1979 XS1100SF
